Help with wiring sub and amp????
Username: Jman223
I have two KICKER CVX12 CVX122 12" subs that run 750w rms dual 2 ohm and a hifonics BXi1606D 1600W MONOBLOCK amp that runs 1600 rms at 1 ohm. Could i wire my subs to 1 ohm or would that be to low and i would need to run them at 2 ohm. Please help!
Username: Nyyfan13
Fi SSD USA
Post Number: 6388
you cant wire 2 dual 2 ohm subs to 1 ohm....only .5 ohm or 2 ohms....you would need 2 dual 4 ohm CVX's to be able to achieve a 1 ohm load....
Username: Jman223
so if i had 2 dual 4 ohm CVX's that amp i mentioned above would work? And also would it ruin the subs or speakers.?
Username: Nyyfan13
Fi SSD USA
Post Number: 6391
yea bud, 2 dual 4 ohm subs wired like in this link (first picture) will give you a 1 ohm load....and no it wont ruin your subs, amps, speakers, or anything for that matter....
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
