Viewsat Xtreme 2000 - Need Help
Username: Majikone
Post Number: 7
Hi
I'm used to keys and download and serial ports with my Pansat.
A friend gave me his Viewsat to update it with DN.
I've dowloaded for the Loader2.exe and DBPSW-070911X.PGM and connect it with the serial port.
I have the regular and twisted Cable
with both cables all what I'm having is Resending and Resending and Resending...
What am I missing here guys or gals....
Thks in advance.
Username: Saqeeb90
Post Number: 107
J use loader 2
use www.totalfta.com
for loading the update.. the update DBPSW-070911 should work..
turn off your reciver from back.. then click on connect on loader 2 .. then when it start sending turn on your receiver from back..
this shoudld work..
also use original cable to download that comes with viewset
Username: Majikone
Post Number: 8
Thanks Sada
It worked for the download...
Does the Viewsat need to be be autoroll off like the Pansat and where it is?
for now it's giving me Autoroll Processing...
Username: Saqeeb90
Post Number: 108
i think there is option called auto tp
put it on or i think it says all
put it on (all)..
leave it for few minutes it should work..
Username: Majikone
Post Number: 9
Thanks Sada
All is workin fine now...
Thanks again...
