PORT?!?!?!?!?!
Username: Bayrent88
Ingleside, Texas USA
Post Number: 110
Whats up Guys
I have a Wedge Shape box thats about 4 cu ft and i want to port it but i am not sure on the sizes...i am building this box myself and i want to put a square port in it...what should i do...oh and its for a 15" L7...thanks
Username: Logan__tille
Team Revolution
Post Number: 8973
Why not a round port?
Username: Bayrent88
Post Number: 111
cause i dont want to go buy one...i don't have any audio shops near bye...the only ones are like 30min away....and i have plenty of MDF to use
Username: Killer44
Ontario Canada
Post Number: 967
u dont have to buy a round port at a shop...im sure there is a home depot or a lowes, or any store selling construction material around you, all u need is a pvc or abs plumbing pipe...most ppl use 3" or 4" diameter...you can even flare them yourself with a heat gun and a bowl...
Username: Bayrent88
Post Number: 112
i don't want to mess with all that..i just wanna make a square port
Username: Bayrent88
Post Number: 113
but a circle does sound easier
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 1...
Post Number: 5307
What are the actual dimensions of the box?
What vehicle?
Username: Bayrent88
Post Number: 114
well the box is a wedge so its kinda hard to explain dimensions
but the box is going into a ford mustang
i found a port calculator online but i need a fequency to tun the box to...how many Hertz should i tune to....
Username: Bayrent88
Post Number: 115
image/vnd.dxfUpload
speaker box.dxf (47.8 k)
Username: Bayrent88
Post Number: 116
well that didn't work
Username: Bayrent88
Post Number: 117
application/pdfUpload
speaker box-Model.pdf (3.3 k)
Username: Bayrent88
Post Number: 118
well yall should be able to read that one if you have adobe reader
A pic is worth 1000 posts!!
Post Number: 10361
Here ya go......
Username: Bayrent88
Post Number: 119
thanks....how did you do that
Post Number: 10368
Username: Bayrent88
Post Number: 120
well...theres what i got designed....so what should i tune it to....??????
Username: Rovin
4 10 Pioneer...
Post Number: 12269
too lazy to check it so what cuft is it ?
those L7 sound rather dull when tuned high so IMO tune it lower 30s ....
Username: Bayrent88
Post Number: 122
were do i check it at...its about 4cu ft not
Username: Phil_salisbury
Post Number: 316
John,
Whats the width of the box for this design and don't forget to say whether there ID or OD, I'll be able to tell you the volume of the enclosure based on the dimensions ya post.
Username: Bayrent88
Post Number: 123
the box is 30"wide.....outside to outside...thanks for the help Phil
Username: Bayrent88
Post Number: 124
i get 4.65 cu ft give or take a little
thats without the speaker or the port displacement
Post Number: 318
Josh,
The enclosure's TOTAL volume is 3.84 cu.ft. before any displacements.
The side surface area subtracting for 3/4" Material total is 233.0984 sq.in x 28.5" ( ID Width ) = 6643.3044 cu.in. ÷ 1728 = 3.84 cu.ft.
Username: Bayrent88
Post Number: 125
ok...well how should i port it....what shold i tune it to
Post Number: 322
Josh,
Here's your box.
simplest approach would be to move the sub to one side and put the port as shown.
Port Size - 4 x 10 x 19 1/2"
Username: Bayrent88
Post Number: 126
sweet....so the port would be alright facing the rear of the car....oh and what program did you use to make that...just curious
Post Number: 323
Yeah, the port is fine firing back like that, unless the port is going to be obstructed by something.
I use Sketch Up to draft the design of the enclosure and I used BBP 6 to calculate the spec's of the design.
Username: Basssquared
Kansas
Post Number: 1335
dayum Phil i gotta give you MAD PROPS that sketch is tight yo WORD to your mother
Post Number: 324
BTW, here's a design I did for a Fi 15 BTL ported for a Stang.
Post Number: 325
Ray,
Thanks on both.
Username: Bayrent88
Post Number: 127
yea i think it might be...what if i ported it on the side....man that other box looks a little to complex for me...it looks badazz tho
Username: Bayrent88
Post Number: 128
what year was the mustang that design was for.....how many cu ft is the box...would it work for my L7...would you be will to give me ur designs for it...
Post Number: 326
Josh,
To be honest, I don't remember the year stang that enclosure was designed for, but, I do know that the designed is based off an existing design I did for a 2002 Ford Mustang GT - Dims - 31" x 10 1/2" x 23 1/4" and then the design what modified to fit the owners stang @ 34"w x 14"h x 27"d.
As for the first design with port firing back.
Here are two other designs with the port firing up:
This one has the port still at 4 x 10 x 19 1/2.
This one, the port is 5 x 8 x 18 11/16
Username: Bayrent88
Post Number: 129
4 inchs wide...that kinda big...but i am sure you know a hole lot more than me on this stuff so i think i am gonna go with it.....oh thank for all you help Phil...you one hell of a guy...what is the box tuned to
Post Number: 327
Port Tuning falls in around 38Hz.
As for the port itself, keep in mind that kicker spec's state the port area for 3 cu.ft. @ 2.5" x 16.25" or 40 5/8" sq.in., so, 4 x 10 = 40 sq.in. of port area is on the mark.
Sweating that 5/8 isn't going to squat one way or the other.
Username: Bayrent88
Post Number: 130
alright...well i think i am gonna put the port on the side of the box...what do you think...
Post Number: 328
well, you can put the port on the side, ya got enough height there at the back.
Just make sure you got the clearance on the side.
Username: Carguy
Post Number: 6513
Woodlawn, what program are you using to design the boxes? Just curious.
Username: Bayrent88
Post Number: 131
he uses sketch up.....
Post Number: 329
Isaac,
As josh already said I use Sketch Up to do the draft designs of the enclosure's, but, I use Bass Box Pro 6 to calculate the enclosure specifications.
Username: Carguy
Post Number: 6516
Makes sense. For the design you posted, it would've been too complicated to do it manually.
Username: Bayrent88
Post Number: 132
the 2d draiwing is mine....i used autoCAD to make that one
Post Number: 330
Before Sketch Up, doing 3 dimensional drafts was a royal pain in the azz to do in 2 dimensions and for years I searched hi and low for a program that I could do drafting and designing to scale in 3D.
The one day on another forum out of the blue someone pointed me to Sketch Up and when I first starting posting sketch up drafts on forums, everyone wanted to know what program I was using and the rest is history.
Username: Tinytruck
Duluth, Ga US of A
Post Number: 62
alright, i hate to mess up yall's flow, but i have a problem...I have a ranger extended cab, with 2 kicker 15" L5's in a sealed box. Inside the box i have filled it with polyfill, and it is a single chamber box. I want to do a round port, simply for the ease of it all. I am thinking about using 4" pvc from homedepot, and using a hole saw that way i am sure to get a perfect circle. MY question is how long do iu need to make the pvc, and do i use 1 or 2 of them? Please feel free to call me (404)-680-4915
thanks-tiny
[IMG]http://i203.photobucket.com/albums/aa95/driver4wb/DSC00145.jpg[/IMG]
[IMG]http://i203.photobucket.com/albums/aa95/driver4wb/DSC00142.jpg[/IMG]
