DIRECTED INSTALL DONE!!!!
Username: Santa_fe
Post Number: 265
hey guys thanks so much for all the help on my first serious sound system....ecoustics is awesome...just a few qucik questions.....is it okay for my battery to run around 12v while the amp is rally thumping???
and i dont have dimming of head lights soo im okay right?? tuned to 50 hz
Username: Santa_fe
Post Number: 267
750 rms!!! i kno its not that much compared to some of you guys but im quite pleased
Username: Santa_fe
Post Number: 268
it will occsionally dip into high 11's but this of course is at idle, im okay right???
Username: Nd4spd18
Northwest PA
Post Number: 3345
you should never see below 12.5 for more than a fraction of a second with the engine running.
If you do, you need a bigger alternator.
Username: Santa_fe
Post Number: 269
its only for a quick second usually its in the mid 12's to 13's...ill go check it again ok...
Username: Santa_fe
Post Number: 271
ok just meterd her again...this time it never went below 12.7...and it prety dang loud lol....so i think im good........
A pic is worth 1000 posts!!
Post Number: 10531
Username: Nd4spd18
Northwest PA
Post Number: 3346
It's probably good then. After all its just 750 rms.
Username: Adddisorder
Palm Beach, Florida
Post Number: 5274
glad to help, your alt should be ok just try not to hammer on it at idle because its putting out less current. also big 3 might help
Username: Santa_fe
Post Number: 273
kool alright yeah i really dont really bump em that much...and idle but ill def becarful....any other syggestion on how to cut back on pwoer useage...i hardlye ever use ac so that one is gone...ill post of pics tomorrow or next day...but right now im really tired lol.
Palm Beach, Florida
Post Number: 5278
if you keep ac off at idle youll get a little more power too, atleast thats how it is in my car.
Username: Joebruce
15 AQ HD3
Post Number: 1534
Awesome man! But you got any pics? Also what all are you running?
Username: Santa_fe
Post Number: 275
ill post some pics tonight for you guys im runni g 650 rms to two q power 12's.......tuned at 50hz...bandpass....i have selaed boxes done juts havent put finishing touches yet
Username: Santa_fe
Post Number: 276
i meant 750 rms directed 1100d briged down to 2 ohms
