2 kicker cvrs vs. 1 diamond d6
Username: Ques07
Post Number: 30
i am getting a rd800.1d... and i wanted to get pair of kicker comp cvr 12" dvc 4 ohms... well the buy didn't have them and told me for 100 more i should get the diamond d6 12 in ported box...with box it's 400 with diamond... with box on kickers it was 300... what should i do
Username: Santa_fe
Post Number: 219
i say kicker
Username: Ques07
Post Number: 31
thats what i said... it would be alot better with the 2 kickers... and i would be getting screwed on money... what if i had him upgrade to the d9 instead... that use my amp fully... right? cause the d6 would get blown with the amp all the way up
Username: Santa_fe
Post Number: 221
hmmm......i think the DVC kickers would pound much harder then the d6 for sure......but...how muhc more will it cost you to upgrade to to the d9?
Username: Ques07
Post Number: 32
i don't know... i'm going to tell him i want it in box for $400... since he was telling me the d6 was 300 for the sub and i can find it for $154... so i'm going to say i'd like a d9 instead cause thats actually a $300 sub
Username: Santa_fe
Post Number: 222
okay, yeah 300 was kinda high but 154....never seen that b4..one d9 as apposed to two kicker Dvc...not sure what will be better...prolly the d9
Username: Ques07
Post Number: 33
if i can get that instead i'm telling him to do it otherwise i'll ask what else he will do.. i found one http://cgi.ebay.com/DIAMOND-AUDIO-D612D4-1200W-12-SUBWOOFER-NEW-06-D6-HOT_W0QQit emZ140164255798QQihZ004QQcategoryZ18803QQcmdZViewItem
^there... there are also a few other places online that are around there... i have even seen it for 200.. but not 300... but i do see the d9 for around there
Username: Ques07
Post Number: 34
ok he got the kickers in so i switched to those he wanted about 600 for the d9
Username: 420alldaylong
Post Number: 2678
I would say Kicker CVR 12s
http://sonicelectronix.com/item_3407_Kicker+05CVR124.html
Go to Home Depot and get everything you need for your box.
Post Number: 2679
Or maybe one Fi SSD 15"
www.ficaraudio.com/
Username: Ques07
Post Number: 35
well the problem is i needed it today... i'm leaving to move and everything... but dhl messed up my shipment on my amp 2 times now so i'm not getting my amp anyways but i went with the kciker comps dvc 4 ohm in a sealed box....
Username: Th3pwn3r
Post Number:...
Post Number: 5234
Go with the Diamond.CVRs sound like crap and aren't very nice subs.
Username: Ques07
Post Number: 36
lol i have owned cvrs and they are very nice in a sealed box... very clean from what i have heard... i used to own a pair
