New box build
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 411
Hey i want to build a new box and need a plan for a box, anyone want to make me one =]. space i have is 28inches in depth, 34inchs wide, and 18inches high. i want to go ported.
Qts: .375
Qes: .49
Qms: 1.506
Fs: 25.5 Hz
Re: 1.8
Vas: 157 L
Mms: 90 g
Bl: 7.2 T*m
SPL: 89.1 dB
Sd: 510 cm^2
Xmax: 9.1 mm
Voice Coil: 50 mm
Magnet Width: 5.250"
Cutout Diameter: 11.000"
Mounting Depth: 5.000"
Weight: 8 lb
Total Height: 5.600"
Displacement: .04 ft^3
Outside Diameter: 12.000"
Box Size Suggestions Outline
Spec
EHQS12 Subwoofer
Sealed ( small )
1.2cF
Sealed ( ideal )
1.5cF
Sealed ( large )
2.0cF
Vented ( ideal )
2.0cF Tuned to 30Hz
Vented ( DDLoud)
2.0cF Tuned to 35Hz
Username: Van_man
Boston South, MA
Post Number: 2922
go to Eds web and check thier boxes
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 1117
http://www.subwoofertools.com/forum/ported-box.asp?Ew=32&Eh=17&Dia=6&Xmax=9.1&Vd =.14&NumW=1&Vb=2&Fb=33&Qts=&Vas=&Fs=&CE=0
Username: Explictx
Post Number: 412
Marc - yeah but i want to build my own i already have before.
Ryan - i need one for 3 subs and im not too fond of that site. i've had some errors with it. thanks tho.
Username: Theweasel
Post Number: 1118
that site works perfectly fine. both boxes i have designed and built on there are perfect
Username: Explictx
Post Number: 413
oh i haven't had too much luck with it.
Username: Theweasel
Post Number: 1119
why what's wrong with it?
Username: Explictx
Post Number: 414
when i put all the dimensions in its always more then 34"in in width and i cant fit anymore then that.
