New member Username: FoxcroftPost Number: 1 Registered: Oct-07 | I'd be appreciated if somebody can answer my problem with combining digital cable and satellite signals in one cable. I've done it using diplexers, but I lost HBO and other pay channels in digital cable. In my understanding, diplexer cutting out some frequencies. Any suggestions? |
Platinum Member Username: LklivesPost Number: 12600 Registered: Jan-06 | U should have no problems with a diplexer...if U have HBO on FTA and cable, then U will have it, when using the diplexer..mine works fine.. |
New member Username: FoxcroftPost Number: 2 Registered: Oct-07 | LK, to be precise, I have ethnic, not dish/dave television and digital Comcast package. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1548 Registered: Oct-06 | It is cutting the old HBO (analog) from cable I think it is ch 14 or 2-15 Not the digital channels that is for sure I bet yo got modem interference This is a rare one But there are ways around it The simplest way is to change brand Diplexer Sometimes inline surge protector or stablizer Must take voltage measurements on your cable Post me your readings Very simple readings if yo got a voltameter Check this section to compare your wiring https://www.ecoustics.com/electronics/forum/home-video/330353.html |
New member Username: FoxcroftPost Number: 3 Registered: Oct-07 | I don't have cable modem. Diplexers - exactly the same as on your photo, but without "King". Talk to the fiend who is with dishnetwork, he said diplexer cutting out 800-1000 mgz range from cable side and this where those channels are. Will try different brand. Thanks guys. |
