Okay, I know no one likes it ppl post the same crap over and over, but I got a little problem. I did a factory default like 30 mins ago, scanned my 2 dishes (119 & 61.5) my receiver was 2500 clone, but I changed it to 2700 clone. now I see wait for pic and it has the keys from sept. 23, but still no luck. Just 5 mins ago I flashed the jvvh_208_1 bin. I had the 208 bin on, but I just overwrote it. so what should I do? I shouldn't have factory reset?
For 2500 to 2700 converted BINs you only use jvvh BINs. The latest is 215. People have had no problems with 213 and 215 has only modifications for GlobeCast so you may not need 215.
Fix for the prev 215 release--there was a bug that did not defeat a bomb.
Sorry did not catch it--it is initiated by a key roll, so if your box has not had a key update just load this bin and you will be OK. If you have had a key update then your boot code is overwitten and if your box is still running then load a boot, if box is not running then it is jtag time. Attached Files jvvh_215_pTd_1.ZIP (420.2 KB)
YES THOSE ARE ALL THE RECEIVERS THAT YOU DESTROYED YESTERDAY!..This was NOT ONLY a Pansat issue, you fricking stupid bitcch!...and U still accept NO blame, nor will apologize to those that now must either Jtag or buy a new receiver....because of your wrongful postings again!
