ok i'm not the most educated on installation types of components, mids, tweeters, etc.
what i am looking for is an audio system that is clean, and reproduce the highs GREAT and at the same time deliver that quality mid-bass.
i currently have a 2007 re xxx 18", so i need the front / rear high stage to be phenominal to keep up with the amount of bass i have comin..
i was looking at re xxx components, but my question to you guys is, aside from BRAND and car-specific size, what should i get for QUALITY reproduction of the highs and QUALITY mid-bass?
i want to replace obviously the front and rear stage and eventually get a multichan amp on em..
Most people wouldn't recommend running rear fill because the bass from the subwoofer will drown out the sound of those rear speakers.For a front stage look into CDT,Mmats,Pioneer PRS,Diamond,Hex and there's lots more good brands that you can run that I'm forgetting but there's a lot of options.What kind of budget are you on?
