Experts please excuse repeating the same question I posted under different subject and help me as I'm in deep trouble.
I need some serious help related to Pansat 2700A. Today, when I was trying to do a channel "sort" using "channel edit" menu option, suddenly Pansat stopped responding. I rebooted it, but it shows "ON" on LCD display and does not respond to any other command.
I have latest bin which working perfact before I did that sort thing. Please HELP!
All, I solved my problem. As I said earlier I was doing the channel sort and my pansat hanged, apparently I had too many channels scanned and pansat just could not handle that many channels. So I hooked pansat to Channel Master, retrieved all the channels, deleted them and then uploaded empty channel lit to pansat and it worked like a charm.
My pansat 2700a is not working at all. I'm not getting any channels. Does that mean that I need a new bin and if so how do I go about getting a new bin. Please help. Thanks
If you're getting some "Wait for a picture" message, then you have to enter the latest satellite keys or load the new/working bin. And, if you're getting some "Bad or Scrambled channel" message, then switch OFF your FTA receiver from the back and wait 10 seconds, then turn it back ON. Good LUCK! .... And If still NO LUCK .... then do a factory reset
Thanks AV. I have tried putting in the new keys and I still get nothing. I'm getting "NO SIGNAL". How do I load the new bin and how do I do a factory reset. Thanks.
Post Number: 12545 Registered: Jan-06 Posted on Tuesday, October 02, 2007 - 01:09 pm:
-------------------------------------------------------------------------------- when using the Clone bins...U must use the CLONE 27.02 loader!...NOT the genuine 2702 loader for
i never knew there is a loader for genuin and loader for clone/
guys is this true ????/// cuz i only use genuin boxes so anyone clear this.
doing a factory default reset, will erase your channels for you, to do a fresh scan. no need to upload the channel list, if you are not going to bother edit the channels while you are in there in channel master, just do a scan after factory reset.
OF Course there are CLONE loaders!...for a year or so, now!...where have U been cartier1?....Clone loaders were developed by the clone coders, so people would NOT be permitted to upload GENUINE bins and KILL their CLONE receivers.. and REQUIRED the use of CLONE loaders to upload CLONE bins!
