Problem with viewset extreme
Username: Saqeeb90
Post Number: 96
my viewset extreme is missing lots of channel
does any one know about channel upgrade software that contains all ppv's +CRICket 1 and Cricket 2 channel...
b/c i tried to scan those channel using frequency and tp's method ... they don't give me any quality signal..
by the way i am using latest bin the one that was released on sep 12
so advance thanks for help..
Username: Lroy
Post Number: 271
Do a factory reset, make sure all settings are correct, LNB freq, LNB type etc, rescan using F1 and you should get all your channels if you antenna is properly alligned....
Username: Saqeeb90
Post Number: 97
thanks for replying but u said factory reset.. on reciever or do i need to load factory bin to my reciever. which bin will u recommend/
Username: Saqeeb90
Post Number: 98
help
Username: Lklives
Post Number: 12483
if U didn't understand lroy, then you're in deep kimchi...he couldn't have made it any simpler...
Username: Saqeeb90
Post Number: 99
LK
Factory reset means on reciever (there is option called factory reset ) or do i need to download Factory bin (via computer), pls make it clear
Username: Lklives
Post Number: 12495
Factory reset means on reciever (there is option called factory reset ...
SOUNDS CLEAR TO ME...
