Camcorder film to my pc is it possible?
Username: Waveone
Hi i have a Canon UC8000 and a fairly new PC (windows XP), i was wondering if there was a way to connect the two so i can get all of my camcorder tapes on to my pc which i can then upload to my website later.
I constantly see sites with video clips and would like ot to the same.
The only leads i have are the scart ones that connect to the TV nothing else can you help?
thanks in advance
Username: Captain
Post Number: 9
yes
Username: Ftalife
Post Number: 228
Yes, you can even edit the videos however you would like with some software.
You should have some usb or some type of cord that came with your cannon camera.
Username: Cochin10
I have a samsung camcorder and a windows xp pc
could anyone please tell me which wires I need to connect to the pc so I can edit it with Pinnacle I dont think i have a 1394 port but i have 5 usb ports thanks
Jim
Need to Register?
Forgot Password?
Enable HTML code in message
