Panstat 3500SD and Dishpro plus LNB
Username: Paulb
Post Number: 20
Panstat 3500SD and Dishpro plus LNB, are the two compatible?? I seem to have issues changing LNB Type on Antenna, Satelite setup. Some Transponders I receive well with Dishpro, and others I use single stack. Is there a good rule for this... or is it a physical LNB issue?
Username: Lklives
Post Number: 12485
DPP LNB's work well with ALL receivers...U have a newbie problem..
Username: Paulb
Post Number: 21
You are right.. can you give me any direction??
You seem to be very active here, giving alot of people advise... That is good of you
Username: Lklives
Post Number: 12489
Use the same exact antenna settings as DP..dish pro...and provide much more info..
which sats...how many LNB's...switches...LNB type (single, dual, twin, quad)
usually its a DPP TWIN LNB (2 sats)...
1 cable directly to 1 FTA receiver...if U have a 3rd satellite then u will need to power the LNB's with a DN receiver or a power inverter...
Twin settings
119-port #1....110- port #2
type-OSD-DP
freq 11250
scan all
22- off
if U have a 3rd sat and LNB then , do this...(legacy is a DN receiver for extra power)...and always leave the DN receiver on..if ONLY the DPP twin, then no need for the DN receiver..
Username: Paulb
Post Number: 22
I have a Dishpro Plus Digital LNBF
I am pointing to 110 and 119, Echo 8.6/Ku and Echo 1.2/Ku, trying to get Orlando FL local channels
I am getting some channels but not many. I have been connected as diagram above
Username: Lklives
Post Number: 12497
U need the DN receiver powered ON always to power the LNB's...and U need your dish aligned and the settings as posted above, but add the echo 1.2 settings also..to port #4
U will ONLY get Orlando locals, if U live near Orlando...
Username: Paulb
Post Number: 23
I don't understand your ports?? Do you mean DisEqc?
Username: Lklives
Post Number: 12501
yes....each input on the disque switch is numbered..and must be the same # as U input into the receiver antenna settings...how else would your receiver know what U have done?
Username: Espn3
Post Number: 86
LK, I need your help.
I have DN ( E7, E8 ) for 2 receivers comming out of 2 LNBs, each with 2 outputs similar to the picture DPPLUS of your post on 9/30, 5:17pm.
The problem I have is that I don't get anything above 12,200MHz ( on TP Scan quality goes to 0 above 12,200MHz on both E7, E8 ). Under antenna setup, satellite, I have LNB Local-Freq. = 10750.
Is there a setting problem or a LNB problem ?
If it's a LNB problem can you recommend a reputable site to buy a similar device ( twin LNB ) with the DPPLUS ( 2 LNBs, each with 2 outputs ) and be able to see above 12,200Mhz ? Are there such devices with 3 or 4 outputs from each LNB ? Or 3 or 4 LNBs in the same device, each with multiple outputs ? Thanks.
Username: Lklives
Post Number: 12552
setting should be 11250...not 10750, thats for linear LNB's and freqs..
Username: Espn3
Post Number: 88
LK, after I changed to 11250 I get quality ONLY above 12200 ( TP scan ). Do I need to adjust the antenna ? thanks.
Username: Lklives
Post Number: 12584
U need to do a scan and tell us what happens EXACTLY, along with ALL your antenna settings...after U do a reboot,set the date and time, and wait while keys update with bin 330 ...
U must provide the complete scenario..this bits and pieces, don't hack it!
Username: Espn3
Post Number: 89
LK, I have 2 FLUs converted to Pansat 2700 and use the jvvh_213_Td.bin which works great.
I'll do a new scan and let you know. Thanks.
Username: Kardary7
Nashville, T.N
Post Number: 12
hi
i want help
i don't know what happen with my ppvu channal or BVE channal ,so any bady know what is wrong or where i can found the new file for pansat 3500sd pleas pleas help thank}}}}
Username: Rtap
FL
Post Number: 521
you can find these files or info at these websites.
future-fta*info
ftabins*net
replace the * for . and register.
all you may need is the current bin file with autoroll fix.
the latest file for 3500 is x-05bl 070929 330api.zip
Username: Lklives
Post Number: 12628
Bec has minor ECM going on...READ this site about it!
Username: Jmill1948
Chester, Va Usa
Post Number: 1072
Thats a fine setup.....after you get a list in chage it to echostar package.works much better
