No Signal, Help setting up Dish....
Username: Bage881
Bridgetown, St.Michael Barbados
Hey, I bought a Viewsat 2000 Ultra receiver a week ago. When I bought it the guy programmed it for me and just told me go home and plug it in( I had Direct TV before so the dish was still in position). I went home and setup the dish ect and had a signal of 65-75% but the channels were searching for hours and I still saw nothing so I went outside to adjust the dish(Oh Boy) who told me to do that...when I came back inside I also reset everything in the settings to default. Then there were no channels?....NONE...Can someone please help me setup my receiver and dish I will post my location and info from SatLex...
Your location:
Latitude:
13.10° N (13° 5' 59")
Longitude:
-59.61° E (59° 36' 35")
City:
Bridgetown
Country:
Barbados
Following values have been calculated for your location:
Azimuth angle:
259.38° (True North)
Elevation angle:
30.96°
LNB tilt (Skew):
73.19°
Offset angle:
0.00°
Distance to satellite:
38529.27 Km
Signal delay:
256.86 ms (Uplink + Downlink)
Declination angle:
-2.14°
Polarmount hour angle:
237.50°
Angle setting on motor:
57.5° West
Satellite:
EchoStar 8/10 (110.0° W)
Username: Tapeman
New York City in-HD, NY
Post Number: 1504
List your hardware
- Receiver (I got that part Viewsat 2000)
- Dish (is it Phase 2 or Phase 3?)
- LNBs (How many LNBs and their kind?)
- DISEqC (Are yo using one?)
- Satellites (What satellites are yo looking to get?)
Along with their brands and BIN PGMs
Keep in mind
Circular LNBs for 61.5/82/91/110/119/129/148 with 20" dish
Linear LNBs for 97/121 with 30" dish
Username: Bage881
I have a Channel Master 4ft Dish and a Standard LNB the one that came with direct tv dish. No DISEqC. Firmware is VS2000 ULTRA Factory Bin File - V0124
Username: Shadycove
Post Number: 92
king,help...will i find 119 to the west of 91?
Username: Tapeman
Post Number: 1506
Well
This can be a highly complicated issue
Based on what yo provided
- Yo got a standatd LNB
- Yo R at Bridgetown, Barbados which requires 4' dish
My main question is what does your LNB look like?
All DSS LNBs use 13V and 18V
But I'm still guessing your LNB require an additional amplification voltage injected Headend Amp/LNB Power Supply
This could be why yo are not getting a lock up signal.
Or it could be your installation process is wrong
I could be wrong since I'm guessing
To confirm this
DOES YOUR LNB LOOK LIKE THIS?
- To find correct angle yo locate true north and start counting angle clockwise or use a compass
- Is your dish aimed correctly?
- Are yo moving your dish/elevation for final tweek?
- Are yo selecting right satellite in antenna setup?
- Are yo selecting right LNB type in antenna setup?
If yo R doing all above correct then it has to be your LNB not compatible.
It maybe was compatible with your previous dish
I would say to avoid any trouble
Just buy a known Circular LNB ($15 off e-bay)
Stap it nicely in place of your LNB
Yo can use your receiver as a satfinder by turning the beep option in your installation setup
Yo'll be up and runing in few minutes
Username: Banti
Post Number: 275
blah blah blah USELESSS SITE
Username: Bage881
nah my LNB looks something like thishttp://www.global-b2b-network.com/direct/dbimage/50344330/Single_Ku_band_Lnb.jpgUpload
Username: Tapeman
Post Number: 1509
Well
If yo got channel lineup with signal and quality but no audio video
Then your guy didn't program it right
Yo said the guy programmed it
Latest bin flash is 070914U.zip or 070911U.zip
Yo need latest bin
Yo need to use your Memory stick
Yo need a Laptop or computer to plug memory stick to load BIN PGM
Yo can get 070911U.zip or 070914U.zip
From
www-dsstester-com (no registration required FREE)
www-DSSCentral-net (no registration required FREE)
www-TotalFta-com (registration is required FREE)
Don't forget to unzip it
Username: Doreenakadj
Post Number: 542
sounds like you have a bad bin without autoroll
I would try one of the sites King has provided and get yourself an new bin (updated)
Username: Tearose_tree
Hello,
can any one help me
from few weeks im not able to watch (Echo 3KU)desi channels always screen have blue messege box NO SIGNAL.
our dish technision who put the dish he do program but still have same situation .
Hello,
can any one help me
from few weeks im not able to watch (Echo 3KU)indian channels always screen have blue messege box NO SIGNAL. i am using dish pro.I tried adjusting in all still no luck.i am getting 71% or62% singnal
Username: Bowshocker
Post Number: 22
when you go to antenna setup does echo 3 flash in top right of screen. im having same issue , echo 3 doesnt flash on top right also signal 76 quality jumps 0-75. unable to lock in echo 3 at all.
IT is weird
