Gold Member Username: 420alldaylongPost Number: 2661 Registered: Sep-06 | How much does a brand new American Bass VFL500.1 cost? |
Silver Member Username: Talon0112 audioque 2.5 144.8 ..., Pa Usa Post Number: 141 Registered: Jun-07 | very expensive seen used go for several hundred |
Bronze Member Username: CblazeTn Us Post Number: 98 Registered: Sep-07 | im not for sure but american bass subs are nice,i got 2 12 inch dx's |
Gold Member Username: Nd4spd18Northwest PA Post Number: 3253 Registered: Jul-06 | A hell of a lot, lol. I don't know the exact price but I'd be very surprised if it wasn't at least $1000. |
Gold Member Username: 420alldaylongPost Number: 2664 Registered: Sep-06 | chris stiles What other subs would you compare to the DX 12's? Thanks |
Gold Member Username: BasssquaredKansas Post Number: 1298 Registered: Nov-06 | my car audio shop carries them and i've heard them before i would say they are like a beefed up CVR |
Gold Member Username: 420alldaylongPost Number: 2665 Registered: Sep-06 | So like a Kicker CVX |
Gold Member Username: InsearchofbassPost Number: 6586 Registered: Jun-04 | we got a dx 10 local for 40 bucks its a decent sub for the price |
Gold Member Username: InsearchofbassPost Number: 6587 Registered: Jun-04 | we hit 135.7 db with it tuned to 45 hz and a restricted port ( two 2 inch ports) on 300 rms but the ports wont let us use all the power http://www.youtube.com/watch?v=-tVshJrV4hY |
Gold Member Username: 420alldaylongPost Number: 2666 Registered: Sep-06 | sean What would you compare the DX 10's? |
Gold Member Username: BasssquaredKansas Post Number: 1300 Registered: Nov-06 | i would say it sits in between the cvr and cvx in out put |
Gold Member Username: InsearchofbassPost Number: 6588 Registered: Jun-04 | well to be honest for us its not a strong low end sub tuned at 39 hz it hit 134.4 db at that tune ....probably because the bl is low but the stats are similar to a mtx 6000 but the 6000 has a higher bl .....the video is playing with a 45 hz tune |
Gold Member Username: InsearchofbassPost Number: 6589 Registered: Jun-04 | scores are at 54 hz burp |
Gold Member Username: InsearchofbassPost Number: 6590 Registered: Jun-04 | dont no if i agree with being the same as a cvr and cvx ....id consider it less of a sub than them |
Silver Member Username: CblazeTn Us Post Number: 105 Registered: Sep-07 | mine are 12's.and they are not the solid black ones,mine are the older ones,and they sound very good and loud,and ya wish u could pick the ones i got up for 40 bucks a piece |
Gold Member Username: InsearchofbassPost Number: 6592 Registered: Jun-04 | the have one of your twelves here local for cheap |
Gold Member Username: InsearchofbassPost Number: 6593 Registered: Jun-04 | opps it is the solid black version like our sub |
