Bronze Member Username: Buddho81Post Number: 39 Registered: May-06 | I just had the new dpp-44 switch installed yesterday and my signal strength is great for all four of my satellites but Quality strength is weak...I get 20-25-35 for Quality...anyone know why this is happening??? I had a dp-34 switch before this and my signal strength and quality were both really strong. I am using viewsat Ultra satellite setup DPP-44 switch 110 -- Input 1 119 -- Input 2 121 -- Input 3 91w -- Input 4 ------------------- Someone help me! Also if I want to have 5 satellites hooked at one time is there a solution for this???? I want to add 82w nimiq to my setup! Thanks in advance |
Bronze Member Username: Buddho81Post Number: 40 Registered: May-06 | SOMEONE HELP PLEASE--- |
Silver Member Username: RtapFL Post Number: 488 Registered: Jan-07 | RKS go to this link.hope this helps.good luck http://sadoun.com/Sat/Products/Dishnetwork/Switches/QuickFacts-Installation_Cons iderations-DP_Plus_44_Switch.pdf |
Bronze Member Username: Buddho81Post Number: 41 Registered: May-06 | What do I need to do to run 5 Satellites??? |
Bronze Member Username: Scorp7Post Number: 50 Registered: Mar-06 | RKS what LNBs u have? If u have dual LNBs (dish Pro) then it has switch buil in and u bring out one cable and still get bothe satellites say 110/119 and 82/91w. That wud still leave you a spare connection. |
Silver Member Username: Micklee11801Post Number: 130 Registered: Feb-06 | He said, he had a superdish. That he will need a 22 switch cause superdish on 110 and 119 are not together. |
