Amp help
Username: Ghavens1981
Lexington , Ky United states
Post Number: 20
is there some kind of a general setting for the gain on an amp mine is turned up about 3/4 of the way is this to high
Username: Kpa2727
Post Number: 650
yes, get a multi meter, dissconnect sub woofers.
burn a 50 hz test tone to cd from
www.realmofexcursion.com
find out your amp's voltage here
http://www.subwoofertools.com/forum/setgain.asp
now remove the subs, put the meter on A.C. VOLTAGE and the subs terminals and with the radios volume 45 percent of the way up and the test tone playing set your gain to the voltage u got from the calculator above. when done your all set, reconnect the subs.
Username: Nd4spd18
Northwest PA
Post Number: 3249
^^^^ Do what he said, except use 75% volume. Thats safe on pretty much any HU.
Post Number: 21
thanks thats very helpful where can i buy a voltage meter
Username: Dannyboyy
O/S Power!!!!, i lo... USA
Post Number: 465
walmart has them buy a Digital Multi Meter and it should have a setting for ac voltage
Post Number: 22
thanks you know roughly how much
Username: Thunderb
Post Number: 51
5-10 dollars
Post Number: 23
thanks
