Alt help
Username: Holt_champ
Htown, MI
Post Number: 862
what size alt should i get to run a 2600wrms system. i did have a 200 amp in my grand am but it didnt work that great.im geting a 03 monte carlo, do they make anything larger than a 200 amp alternator for those cars?? anymore suggestions??
Username: Nd4spd18
Northwest PA
Post Number: 3224
The biggest you can get. 200 amp should work though. I'm running a 3000 watt amp on a 200 amp alt and a 1500 amp Odyssey battery. Works good.
Htown, MI
Post Number: 866
well i had 200 amp in my grand am with 2 optima batteries. the voltage dropped really bad. does it have anything to do with what kind of car? i know grand ams are kinda poor quality.
Username: Nd4spd18
Northwest PA
Post Number: 3236
Could have been a wiring issue. Mayble the big 3 wasnt done right, sometihng along those lines. IDK
Htown, MI
Post Number: 867
is there a way to check how many amps the alternator really is??
Username: Nd4spd18
Northwest PA
Post Number: 3239
Yeah but you need some expensive equipment to do it.
Htown, MI
Post Number: 868
are there any places that can or will do it?
Username: Nd4spd18
Northwest PA
Post Number: 3246
Not that I know of. Auto parts stores say they can but they don't do it right.
