Words coming out of subs,
Username: C_stan1016
The words are coming out of my subs and I was wondering how to fix it. Anyone with any info let me know please... Thanks,
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1881
change the filter setting on the amp. from HPF to LPF
Username: O0airjordan120o
MN US
Post Number: 72
your amp should have a switch on it. HPF FULL and LPF. HPF is for higher frequencies like the words. LPF is low like bass and full kinda uses both. juss switch to HPF
Post Number: 1882
to hpf huh???
MN US
Post Number: 73
nooo i ment LPF!!!!!!!! lol.
Username: Jtown
Post Number: 411
or if you have a nicer amp, turn the lpf down to like 80hz
Username: Th3pwn3r
Post Number:...
Post Number: 5080
Set your low pass filter to anywhere under 100 hz.
Username: Th3pwn3r
Post Number:...
Post Number: 5081
^I said 100hz in my post because I have no idea what kind of sub you're running or what kind of tuning the box has that you have the sub in but 100hz is a tiny bit on the high side as far as most applications goes.
