Silver Member Username: Santa_fe
Post Number: 197 Registered: Jul-07
Posted on how can i do this??? just make an adapter from some wood??? how much do the adapters run?? crutchfield seems rather expensive |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5049 Registered: Jul-06
Posted on I'd stick with 6.5s if I were you.There's more options for speakers to my knowledge in that size... |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 5089 Registered: Jan-06
Posted on yes you can. |
Post Number: 198 Registered: Jul-07
Posted on yeah i want to go 6 and 1/2 but my slots are 6 and 3/4 anyone have ideas or steps to make brackets for these spots??? |
Gold Member Username: Bernymac
BME
Post Number: 3322 Registered: Sep-04
Posted on make an adapter out of wood with a circumference of 7 3/4 inches and a inside diamter to accomodate the 6 1/2 speaker. |
Bronze Member Username: Vivi2000
Post Number: 11 Registered: Aug-07
Posted on Ive seen speakers that have the diffrent screw holes for 6 1/2 and 6 3/4 on one speaker so lok for that mabye? |
Post Number: 199 Registered: Jul-07
Posted on will do jonny |
Bronze Member Username: Sqhoe
Huntington,
IN
Post Number: 49 Registered: Mar-07
Posted on My ADS comps came with an adapter to go to 6 3/4. |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 350 Registered: Jul-07
Posted on lol with my car i just cut bigger wholes lol |
Post Number: 204 Registered: Jul-07
Posted on ryan do u want thoes adapters...ill buy them from ya |
