Clipping???
Username: Cplaya280
Quakertown, PA USA
Post Number: 705
How can you tell if you are clipping your amp and/or subs is there something i should be listening for like distortion or something or any other ways to tell?
Username: •cam•
Post Number: 705
Yes you're listening for distortion, but you need a highly tuned ear to do it reliably, from what I hear. The only way to tell for sure is with an oscilloscope. They are expensive, but if your in school and they have an electronics class, you may be able to use one of theirs.
Username: Cplaya280
Quakertown, PA USA
Post Number: 706
no im not in school so that wont help
Username: Nd4spd18
Northwest PA
Post Number: 3231
You set your gain right and then you dont have to woory about it.
Username: Cplaya280
Quakertown, PA USA
Post Number: 707
yeah and how do u set the gain correctly i got a dmm meter and everything but i still dont know how to set the gain correctly
Username: Nd4spd18
Northwest PA
Post Number: 3234
Calculator:
http://www.subwoofertools.com/forum/setgain.asp
JL's fancy demonstration:
http://mobile.jlaudio.com/support_pages.php?page_id=143
