Question for AV or Lk
Username: Detroitd
Winton, Ca. U S A
Post Number: 7
Does you know if the new or current bin jvvh 213Td for converted 2500 pansats is compatable with tivo, I do not want to convert my pansat 2500 until I am sure it will work with my tivo series 2 thanks for any Info.
Username: Asharfi
Post Number: 850
detroitd mich,
Try to convert your Pansat 2500 - Pansat 2700 and if you're NOT happy with it, then just simply swicth back to Pansat 2500. I don't think it'll work with tivo.
Username: Lklives
Post Number: 12191
Oobviously he has, or is considering the 2700 conversion, or he wouldn';t have asked about the "jvvh" file...
I have seenesen NOTHING that states its for Tivo...as U know the regular v2700 clone file (for non coverted 2500 receivers) 213 v1 w tivo is for 2700 clones...
