Username: Gujugangsta320 Post Number: 10 Registered: Aug-07
Saturday, September 22, 2007 - 22:58 GMT K..im tryng to get bev to watch india vs pakistan finals..i noticed a post said u can watch on bev..i just want to know how do i get bev?..I have 2 Dishnetwork Dishes..119 and 61.5...Will i need another 1?...will i need a differ lnb?...and wat channel will it b on?.....o and i got a pansat 3500 =)...hope this helps
Username: Dimwitt Post Number: 123 Registered: Aug-06
Saturday, September 22, 2007 - 23:07 GMT same dish n lnb type will work for bev bev sats 82 & 91w
Username: Lklives Post Number: 12195 Registered: Jan-06
Saturday, September 22, 2007 - 23:09 GMT Bev is Canadian satelitte TV orbitting the 82W and 91W ...obviously U need to have a dish and LNB aimed at those!...its like steering the car, U can't get to the supermarket if U are aimed at the library!
Username: Asharfi Post Number: 851 Registered: Aug-06
Saturday, September 22, 2007 - 23:13 GMT Yep .... if you want ... you can just simply point your old sats to nimiq 1 and 2
Username: Tapeman New York City in-HD,
NY
Post Number: 1501 Registered: Oct-06
Saturday, September 22, 2007 - 23:18 GMT I would take the 61.5 dish and move it 30 degrees clockwise to get 91 Elevation yo must be on East cost I'll move it slightly down. That's it 30 degrees clockwise and few degrees down. 30 degrees towards west is like if 61.5 at 8 o'clock 91 will be at 9 o'clock. draw black marker line as a reference. Scan the satellite few minutes yo'll be up and runing otherwise yo just ran out of luck
Username: Gujugangsta320 Post Number: 11 Registered: Aug-07
Saturday, September 22, 2007 - 23:47 GMT o i almost forgot..i live in the US...would it matter?
NY
Post Number: 1502 Registered: Oct-06
Sunday, September 23, 2007 - 00:11 GMT Well in that case technically you are not supposed to get it. But it is all up to yo if yo want to follow the law
Username: Gujugangsta320 Post Number: 14 Registered: Aug-07
Sunday, September 23, 2007 - 00:30 GMT lol..well mad pepz get..and if it is against law then i just wanna see if itll work..im not gettin untrouble..
