Atenna setup
Username: Charjam
Post Number: 205
Hey i am trying to setup my friends FTA but we can't get anything . I took my lnb's from my atenna so i know they work but he has a dish that has a snow cover on it would that be the problem . We have a meter but we can't seem to get anything Help Please
Username: Gujugangsta320
Post Number: 9
i probably think the snow cover is the problem =/....well if u have a birddog meter check if the signal is ok..mayb like around 75 to 99..then if its good just move it like about half an inch to find quality, if that doesnt work...try taking of the snow cover then try it...hope that help =)
Username: Tapeman
New York City in-HD, NY
Post Number: 1499
List your hardware
- Receiver
- Dish
- LNBs
- DISEqC
- Satellites
Along with their brands and BIN PGMs
Keep in mind
Circular LNBs for 61.5/82/91/110/119/129/148 with 20" dish
Linear LNBs for 97/121 with 30" dish
So if yo took an LNB to a different dish it may require moving LNB to get the right focal amplification this concerns size of dish
So rather than guessing what hardware yo got
Provide a complte list of all hrdware like I have above.
Username: Charjam
Post Number: 206
i have a pansat 2500 with bin 288 trying to get echo 7 and 8.6 it worked with his lnb's good quality but we could only get 137 channels and a lot of them would not come in . Right now we pulled it out and i am taking it to my other home where i can fool with it when i know everything is good i have used this receiver for a long time so i know the lnb's work so i will keep you posted but thanks a lot for the reply i will probably put the file in for 2700 and the 213 bin
Username: Donnie1973
Post Number: 858
yeah, u need to tell antenna set up. Disecq's, lnb type
If it was covered in snow... well, it prolly wont work
Username: Charjam
Post Number: 207
How do you tell the diff. between a circular LNB and Linual LNB by just looking at them Thanks for all of the replys
