No signal
Username: Maltster
i seem to continually lose the vertical polarity channels on bev. if i do a factory reset and rescan everything comes back. is there a solution staring at me ??
Username: Tapeman
New York City in-HD, NY
Post Number: 1493
Loosing vertical polarity means you are loosing DC voltage 13/14 Volts
Reason(s)
- Coaxial short or moisture on one of many cables
- DISEqC input mismatching multiple receivers
- Short on DISEqC switch or LNB
- Use of splitters
- Bad cabling or connectors
- Wrong antenna setup
List all hardware yo got (i.e. no stories)receivers, LNBs, dish, cables etc. Include # of multiple receivers.
Username: Maltster
thanks for the response; i am using a fortec cloned to a 2700 pansat, single standard lnb (approx 10 yrs old); and i am splitting the signal to power two receivers, using an old regular tv cable spliter. do i need to rescan every time? or is there a better spliter out there
Username: Tapeman
Post Number: 1497
All yo need is an LNB that has 2 outlets
Called Dual Circular LNB ($15 off e-bay)
1 Coaxial input to each receiver
Yo can't use splitters or yo'll have polarity problems just like what is going on now.
Circular for 61.5/82/91/110/119,148 with 20" dish
Linear for 97/121 with 30" dish
If yo have Multiple Satellites and would like to use both receivers then Yo need a DISEqC switch. It looks like a 4 input splitter but the right kind for high frequency required for satellites
2 DISEqC (1 for each receiver)
Also required to match each input to each LNB of satellite respectively. Along with simple antenna setup.
Username: Tapeman
Post Number: 1498
What yo are saying doesn't make sense to me regarding polarity problems.
The part were yo are splitting
I would try to eleminate problem by not using splitter.
Yo have to provide a list of hardware
So I don't have to guess what yo got
They maybe a better bin for your fortec or didn't use correct bin to start with.
If yo got only one receiver and would like to share to different rooms
Click here
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1063352#POST1063352
LIST ALL YOUR HARDWARE
