Username: Cplaya280 Quakertown,
PA
Post Number: 708 Registered: Oct-05
Wednesday, September 26, 2007 - 00:21 GMT ok i was removing the stripped allen screw on my amp for the 12V slot and i took everybodies advice on here that gave me and i drilled it out and it worked but now the problem is now the hole is to big to replace it. i took the allen screw from the ground wire slot just to see if it would fit and i can start to screw it in but then it just falls all the way through i cant even secure the wire now what can i do to fix this
Username: cam Post Number: 709 Registered: Nov-06
Wednesday, September 26, 2007 - 00:36 GMT you drilled it out too big. you can probably just re tap it. you could probably find a tut. fairly easily with google.
Username: Hgihkcin Lincoln,
NE
Post Number: 271 Registered: Sep-05
Wednesday, September 26, 2007 - 00:39 GMT get a self tapping screw at the hardware store, bring in your amp and show them how big the hole is they will hook u up
PA
Post Number: 709 Registered: Oct-05
Wednesday, September 26, 2007 - 00:44 GMT so i can just use a self tappin screw and it will work just as good. would i wanna screw it all the way through or just until it touches the wire
Username: cam Post Number: 711 Registered: Nov-06
Wednesday, September 26, 2007 - 00:53 GMT just as far as you need to. make sure it's flat on the tip (like a regular bolt, not like a wood screw).
PA
Post Number: 710 Registered: Oct-05
Wednesday, September 26, 2007 - 00:55 GMT why would it matter?
Username: Jesse59672 OKLAHOMA
Post Number: 666 Registered: Feb-07
Wednesday, September 26, 2007 - 03:50 GMT so it has more surface area pushing down the wire to the amp's terminal. if it has a skinny tip its not going to hold the wire very well..
PA
Post Number: 711 Registered: Oct-05
Wednesday, September 26, 2007 - 04:17 GMT ok i used a regular self tappin screw and it works great thanks a lot for the advice
