RE SE RMS
Username: Kaerfpl
Spencerport, NY USA
Post Number: 562
The SE's that I have say that they have a 600 Watt RMS but, on the box it says they can handle up to 2000 Watts! Is this true or just a huge overstatement? Not like I would give them that much anyway...
I know that a few of you guys on here had some SE's before and im just curious onto how much power you gave them?
Username: Joebruce
15 AQ HD3
Post Number: 1430
Its prolly 600wrms and 2000 watts peak. Dont pay attention to peak power. It means nothing.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 563
The peak on these are 1200 Watts and the RMS is 600 Watts.
Username: Cenus
Hicksville, Ohio
Post Number: 3593
where are you getting 2000wrms from? do you mean 2k for burps? se's can handle 1000wrms in a good box, for daily i wouldn't go over that.
Username: Trans_am_ls7
Lincoln, NE
Post Number: 75
Logan was pushin 1700 on 1 10" SE u got to see the video!!!!
i got 2 12" SE on a usamps XT2000D
Username: Kaerfpl
Spencerport, NY USA
Post Number: 564
On the box that the SE's came in, it says that they can handle up to 2000 Watts.
Wow, 1700 Watts? I was only thinkin about putting about 750-850 Watts on each, lol.
Username: 420alldaylong
Post Number: 2638
A friend of mine had a kicker ZX1000.1 on a RE SE10" for daily and never had any problems.And he was beating the sh!t out of that sub.
Post Number: 2639
It's all in the box.
Lincoln, NE
Post Number: 82
yep Logan had a BIG Azs box for his 10"
Username: Kaerfpl
Spencerport, NY USA
Post Number: 565
Im customizing a box for my SE's as we speak! All it needs is the holes to be cut and terminal to be put in, then carpet. 2.5 cu ft tuned to 35Hz.
