Low Cost sub option - for the well versed
Username: A3forme
Post Number: 423
I'm looking for a single 12 in sealed or ported (max dims 14*14*28)enclosure. I listen to rock/pop/alternative, and ocassionaly metal. Never rap or hip hop, except for the occassional classic Nuaghty by Nature's "OPP" .
I'm looking for Clean, Clear, Punchy bass, not booming. I want to be able to hear it significantly in my car, but I don't care if the rest of the world hears it.
The vehicle is an '07 HHR and I'm looking for something that will blend as well as possible with CDT CL-S60A or Alpine Type R 6.5 components. Mid-bass at this time is not an option.
There will be 600w RMS available at 4ohm final load. This is bridged power, so other resistances are not an option for a single sub.
I was thinking of an Infinity Kappa Perfect 12.1 as 1 sub that might fit the bill, but they're hard to find. And the VQ is kinda out of my budget.
I'm looking to spend MAX $150 but really more like $100-125. I know that doesn't help much.
So please offer up your suggestions.
Thanks!
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 462
with that budjet u shuold prolly go type r or spend twenty more bucks and pick up an SI bm
Username: A3forme
Post Number: 424
Josh,
Thanks. Sorry, I've been out of this for a couple years, what's an SI bm? A link would be good. Thanks
Post Number: 465
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=23_24&products_id= 37
from what i hear around E this is a good sub and a good price.
Username: Talon01
12 audioque 2.5 144.8 ..., Pa Usa
Post Number: 129
diyma or image dynamics
Username: 04redmach1
Columbus, GA USA
Post Number: 1351
Mazda, Josh gave a great sub to check out. If that doesn't fit the budget, I have a GREAT deal on a sub that fits your budget and what you need. shoot me an email on help with the BM or another option.
Kevin
lowhz01@yahoo.com
Username: A3forme
Post Number: 425
While that SI BM looks like a nice sub, it only comes in dual 4ohm. I need single 4ohm or Dual 2ohm
Kevin - Email sent.
Post Number: 467
ooooo true true. kevin will hook you up and hes a good guy. shoot him an email bro.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 464
AA Assassin 12
http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=160
Username: Denim
Post Number: 465
My mistake, misread, you need 4 ohm final for single sub.
Username: Denim
Post Number: 466
Kicker L5 on ebay is a good idea.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1575
"Clean, Clear, Punchy bass"
An L5? If it's anything like my L7, that definintly won't fit his description.
Username: Denim
Post Number: 467
That is entirely dependant on the install.
Username: B3n07
Louisville, Ky USA
Post Number: 340
that infinity would be perfect by its self my mom listens to the same stuff (except the OPP part) but she has 1 10.1 and its awsome sounding you hear it in the car and you can also give them more than recomeneded power go with the infinity you will like it better
Username: Hdubb
Team Revolution
Post Number: 2417
type r maybe .cvr?
Username: Skibum12189
Cleveland
Post Number: 1724
i ahve 2 12" Stereo Intergrity BMs (SI BMs) and they sound awesome...one will give you the nice punchy, tight bass you're looking for.
