New member Username: RaidersfanPost Number: 1 Registered: Sep-07 | I want to add 91 to my current setup (110/119), however I cant seem to find how to align it. So far I know I need a 3rd lnb but do I need to adjust my dish or do I just add the 3rd lnb to one of the sides?... Is it even possible to get all three without some sort of braquet?... Any help would be greatly appreciated... and if anyone has links to other posts that explains how to do it that would work to.... thanks in advance... |
Silver Member Username: RtapFL Post Number: 462 Registered: Jan-07 | jesse it is easier to setup another dish for 91.reason being between lnb there is a difference of 9 degrees.once you've done this just go to this site and read. Satellite Finders (Look Angle Calculators) ------------------------------------------------- [link removed] http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm |
New member Username: RaidersfanPost Number: 2 Registered: Sep-07 | Hey RTAP thanks for the info but I have no idea how to apply that info(AZ t&m, EL and skew)... I dont even know what they mean. would I need some tool? Is there any other way? |
