PLS HELP pansat 3500
Username: Vicb
Post Number: 19
all was working fine with my pansat 3500 until to day all channels read scambled. so i am rebotting the 328 bin and now it wont even take a download?? never happended before ?? any ideas??
Username: Rtap
FL
Post Number: 460
what does it exactly says
Username: Vicb
Post Number: 20
well im at my computer reloading the bin file but it wont even download.. this what ive heard of jtagging or resetting the box??
Username: Vicb
Post Number: 21
should i do a factory rest.. rescann channels and re boot bin file
Username: Rtap
FL
Post Number: 461
did the display on stb show any lights. remember jtagging is when stb is completely dead or trying to acces the ecm directly. and from what your saying you do not need this procedure.try loading the bin file to your sd card then to your stb.
Username: Vicb
Post Number: 22
ok all is daz good now.. i put it back in tv and its working.. wew :-)
