International 61.5 missing
Username: Newtek
any one have the same problme, since last night, no 61.5 just says autoroll,
loaded factory bin
reset factory
search
110 ok
119 ok
91.5 ok
61.5 get the channels but no pic
Username: Viruscauser
Leesburg, Georgia
Post Number: 264
LOL.
Receiver?
Bin?
Username: Banti
Post Number: 250
do a factory reset try another bin. then set defualt keys and let them load...
Username: Newtek
did factory reset, loaded factory bin, loaded new bin from ftalife.kom, using vs pro.
question no one else with problem not recieveing 61.5 ?
Username: Lklives
Post Number: 12130
REBOOT the receiver with rear switch...recheck the antenna settings in the receiver...and then the cables/connections from 61.5 LNB and switch..
Username: Newtek
turned box off in back for 5 min, reset factory option and with bin
question if you reset to factory should the keys reset as well?
signal strenght excellent, and i do get zee sports but that's it
Username: Lklives
Post Number: 12135
did u do a new F1 sat scan...
BTW...keys stay..
Leesburg, Georgia
Post Number: 268
gerard what is the Zee Sports channel number and freq?
Username: Tapeman
New York City in-HD, NY
Post Number: 1444
Charlie is doing a lot of tests at night
Avoid Scanning or re-scanning at late hours
I see something coming within few hours or few days affecting 61.5 International
Username: Mrskullz1
Brooklyn, New York
Post Number: 763
wht exactly do u see?
Username: Tapeman
Post Number: 1445
I see dead people
Username: Tapeman
Post Number: 1446
When I said long time ago there were 2 sets of transponders like two streams everyone said I was crazy.
I say they are doing experiments between 2:00A and 6:00Am (EST) They are enabling certain TPs and disabling others. TESTS I don't know what tests I can only guess what tests:
Either the transition of HD and SD channels
Or procedure do drive hackers crazy
Or simply both
Username: Newtek
Using ViewSat Pro,
loaded hardwire factory bin, loaded newbin vspro 070911a, replaced LNB, removed Diseq, strait shot
did blind scan no luck,
61.5 still showing Auto Roll Processing
tryed turning off autoroll nothing
Username: Newtek
Post Number: 7
I do get ch.576 zeesa frq.12384MHz
Username: Mc_sunny
Post Number: 1220
For Viewsat Pro Only !!
Everyone's got the "autoroll processing" message for 61.5 sat and 148 on the the VSpro only!!
They are looking into it. you should see a fix for this very soon.
Username: Dimwitt
Post Number: 118
please listen to klingk , everthing is going down
Username: Scorp7
Post Number: 44
I have CS5K and yes on blind scan I get like 4 channels of each, two different frequencies and V/H polarity each. I think that confirms Kings theory. Also last few days some channels are missing - looks like they have changed the TPs. But then on rescanning you dont pick up those channels. Quality level on those Tps suddenly down to 5% in red. Yesterday one set had a problem - today another set of channels have same problem. What is going on and why only 61.5?
Username: Crazy_greek
Post Number: 1148
Hey, gerard
EchoStar 3 @ 61.5W (tp 12) Freq.12384 has no listing for Channel 576 or Zee Sports.
Dish TV from India carries Zee Sports.
NSS 6 @ 95.oE (tp INVC2) Freq. 12595 (Pol. V )
SR 40700 Channel 25105.
Something don't Jive here.
A) Spot Beam = India
B) Lot of Zee Channels, but you are only picking up Zee Sports.
C) I don't think that this has anything to do with King's guessing game.
BTW are you for real or this is a setup?
Username: Tinfish
Post Number: 126
mcsunny is right..all vspro users are seeing autoroll on all international birds. hopefully a new bin update will fix this.
Username: Tapeman
Post Number: 1471
McSunny is right
But Kavin is right too
There are multiple streams of TPs
It is worth the shot to capture same programs at different TPs
Post Number: 1149
Hey, storyteller
Are you telling us a story, that everthing is going down?
What do you suggest we should do?
Username: Newtek
Post Number: 9
Wow Lots of questions,
Here is the thing same LNB
two Fta's
Xiewsat Pro with no 61.5 (NEW BIN)
and Xoolsat 4000 Pro and I do get All 61.5
So I will bet my balls it's the Bin
What's next I don't know
I can only hope it's not the Dark 9 months I had to go through back in the days
Yo Know what I mean, jelly bean!
thanks, we love you hackers...
Username: Tapeman
Post Number: 1495
On the Viewsat
If I were yo
I will try load program over without blind scan
Just do Chan sat Scan F1
Avoid installation past midnight
Charlie is playing with settings while everyone asleep
