91 bird setup??
Username: Vhl71
Post Number: 62
i only had 82 so far..want to repoint my dish to 91..dont have the satellite meter..is there a way i can do this without the tools? i assume i need to move the dish horizontally.not vertically..
any ideas as to how to repoint from 82 to 91?
pls help
Username: Nbn
Post Number: 249
you need to do both. turn west a couple of degrees and up a few inches .. mark the current position of your sat with a marker so you can find it again
Username: Tapeman
New York City in-HD, NY
Post Number: 1459
If yo put a twin LNB you get both 82/91
One coaxial cable no DISEqC required
Minor tweek elevation but skew is a must
If yo want to run single
82 to 91 yo turn few degrees clockwise
Username: Vhl71
Post Number: 63
thanx..obviously without any tools, its kinda tough..my ariza says i've signal nimiq1..but when you scan it is still nimiq2..
i have the angle marked in the dish bracket..it is at 50deg now. (the vertical one)..
what should i do first..move it up vertically a little and fix that and then turn sideways till i get the signal..
i know its kinda dumb to do it blindly..but for now thats my only choice!!
Username: Vhl71
Post Number: 64
thanks king..
so rotate it up a bit and then move it sideways??
Username: Nbn
Post Number: 250
the tool for a sat is $1 , a 10 or 11mm wrench
yes up a few degrees and west
Username: Nbn
Post Number: 251
up first then scan the sky with a left to right , if you miss it drop the angle up or down 1 degree and scan left to right again. you can hit every sat this way in about 3 minutes
Username: Tapeman
Post Number: 1463
So I take this as Yo don't want both at same time
No need for tools
Many receivers got the beep option if yo can turn beep option on
If want run single 91 yo turn pole slightly towards west (It is what I call clockwise). Elevation also slightly.
Elevation:
If yo are on east cost 82 to 91 yo move down
If on West cost 82 to 91 yo move up
But it is better to calculate it
http://www.kusat.com/install/calculator2.php
Username: Vhl71
Post Number: 65
thanx
i need only one 91 as i don't have dual lnb at present.
i'm on the east coast so i need to move down then.
can i just loosen the screw and move the dish only?
Also I cant get this calc..it says azimuth 183.76 elv 39.62 for 82 which i have right now..
all i see without the compass is the angle scale on the bracket which is at 50right now..
how do i exactly position my dish in azimuth 183.76 and 39.62
Username: Tapeman
Post Number: 1466
Those readings never acurate
Just move dish slightly (down and to West)
Fine tweek and yo'll be there
I would make a marker line for both Elevation and Azmith AS A REFERENCE. It is not hard. If there is no luck bring it back on marker line step and repeat.
What receiver do yo have?
Username: Vhl71
Post Number: 66
i have an ariza
thanx a lot guys..being first time (with dish pointing) after a bit of struggle, got 91 lined up..i had to swing a bit to west to get 91 (from my current 82 position)..
