Bronze Member Username: JerkislandPost Number: 21 Registered: Mar-07 | Guys, Attached is the setup I have, is this right for Bev ? I will be connecting a PANSAT 3500SD by running a cable where it says to the receiver. Do I need anything else ? Please let me know |
Platinum Member Username: LklivesPost Number: 12146 Registered: Jan-06 | The Plus Dish is designed to pick up the 110°, 118.75° and 119° orbital slots with an option to add 129°. Dish 500+: 110°, 118.75°, 119° Dish 1000+: 110°, 118.75°, 119° and 129° Information Special dual-band LNB for 119°/118.75° The 500+ also gets 110°; the 1000+ adds another LNB to bring in 129°. Measures 30.9"W x 23.8"H Requires an external switch Plus Dish 500+ on the TechPortal Pointing Angles (PDF) Channels available at 118.75° |
Bronze Member Username: JerkislandPost Number: 22 Registered: Mar-07 | LK, Thanks for responding but the superdish I have is for Direct and not dish.Will this setup work ?What should I look for in Antenna setup ? |
Platinum Member Username: LklivesPost Number: 12147 Registered: Jan-06 | Now U say U have a Superdish...before U said U had a Dish 500 plus with a pic...they are completely different dishes...and Superdish is for DN, not DTV....cannot help U, until U know what U're talking about ... |
Gold Member Username: NydasPost Number: 3815 Registered: Jun-06 | This is LK's help. She is a pest. Be careful. LK Platinum Member Username: Lklives Post Number: 12158 Registered: Jan-06 Posted on Thursday, September 20, 2007 - 06:03 pm: in the "New Keys" thread Do U even have a dish?... does it have LNB's... are they aligned correctly at whatever satellites U want.... are cables and connections rechecked have U rechecked your switch.. did U input the latest bin is autoroll turned ON... did U set default key first did U wait patiently for keys to autoroll did U reboot.... is receiver antenna settings configured the same as your cables and switch ports and type... have U read at least 10 hours before attempting this hobby... do U have a manual for your receiver... have U read it lately... |
Bronze Member Username: JerkislandPost Number: 23 Registered: Mar-07 | It is DTV International Dish Antenna sized 36" x 24". Do I look for 95W and 101W satellites in Antenna Setup ? |
Platinum Member Username: LklivesPost Number: 12161 Registered: Jan-06 | Nalin ...U only copy/paste my posts and do NOT provide ANY useful purpose here...U are a disgrace to your own people... Dum....U cannot get Directv, unless U subscribe....so forget DTV 95-101.. |
Gold Member Username: NydasPost Number: 3824 Registered: Jun-06 | LK only understands Braille these days. You could have asked in plain normal easy to understand (even by LK) English that "What LNBs should I buy to use with this huge Dish I have?" and she would have said "You can install 4 cheap LNBs on an arm and get all the different channels." Mind you I am not LK I am that dumb guy who does not know a thing. |
Platinum Member Username: LklivesPost Number: 12164 Registered: Jan-06 | Atlanta Air Traffic Control: "Tower to Saudi Air 911 -- You are cleared to land eastbound on runway 9R." Saudi Air: "Thank you Atlanta ATC Acknowledge cleared to land on infidel's runway 9R - Allah be Praised. Atlanta ATC: "Tower to Iran Air 711 --You are cleared to land westbound on runway 9R." Iran Air: "Thank you Atlanta ATC. We are cleared to land on infidel's runway 9R. - Allah is Great. Pause: Static.. Saudi Air: " ATLANTA ATC - ATLANTA ATC" Atlanta ATC: "Go ahead Saudi Air 911?" Saudi Air: "YOU HAVE CLEARED BOTH OUR AIRCRAFT FOR THE SAME RUNWAY GOING IN OPPOSITE DIRECTIONS. WE ARE ON A COLLISION COURSE. INSTRUCTIONS, PLEASE. Atlanta ATC: "Well bless your hearts and praise Jesus. Y'all be careful now and tell Allah 'hey' for us." |
Bronze Member Username: JerkislandPost Number: 24 Registered: Mar-07 | Guys, All I want this channel Bev ch 703 (satellite 91)..I had DTV before and now I don't, so I want use that same dish and get this channel and other Asian Channels. Also I have DP34 Switch, can I use the same along with this dish ? Please let us know. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1464 Registered: Oct-06 | Dude LK is right the dish is for Dishnet The Middle LNB is for the FSS 118.75 The 2 side LNBs CAN get 91 or 82 With careful installation can get both Not easy but possible I would cover middle LNB with a paper cup or tape If possible not even plug the coax in I always thought Middle LNB has to be the FSS I never seen one but even if it is the side LNB can still get both birds. In that case yo don't need to cover LNB Not for a noobie to test but what the heck give it a shot. I'm here if yo got questions |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1465 Registered: Oct-06 | Ooops I only saw first post If your dish is a DTV Yes yo can only get either 91 or 82 with the LNB that gets 101 They won't be blockage on that LNB Yo'll need to repoint dish turn dish slightly counter clockwise and elevation also slightly up or down based on your location 101 to 92 (East cost yo move up, west yo move down) |
Bronze Member Username: JerkislandPost Number: 25 Registered: Mar-07 | Thanks Guys, where can I get exact elevation and other information to point the dish to get BEV channels. Also what is satellite I need to look for in the Antenna setup ? |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1467 Registered: Oct-06 | http://www.kusat.com/install/calculator2.php |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1468 Registered: Oct-06 | I wouldn't worry about calculation Draw a marker line as a reference on both Elevation and Azmith Angle. If yo make a mistake start all over from reference line Since yo are there at 101 Yo'll need to repoint dish turn dish slightly counter clockwise and elevation also slightly up or down based on your location 101 to 92 (East cost yo move up, west yo move down) Very small tweeks Turn on Beep option if yo got one on your receiver |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 3157 Registered: Nov-06 | Dude, King is right. Here's what needs to done. http://i4.tinypic.com/4pv97wg.jpg |
