Is the following setup right ?
Username: Jerkisland
Post Number: 21
Guys,
Attached is the setup I have, is this right for Bev ? I will be connecting a PANSAT 3500SD by running a cable where it says to the receiver. Do I need anything else ? Please let me know Upload
Username: Lklives
Post Number: 12146
The Plus Dish is designed to pick up the 110°, 118.75° and 119° orbital slots with an option to add 129°.
Dish 500+: 110°, 118.75°, 119°
Dish 1000+: 110°, 118.75°, 119° and 129°
Information
Special dual-band LNB for 119°/118.75°
The 500+ also gets 110°; the 1000+ adds another LNB to bring in 129°.
Measures 30.9"W x 23.8"H
Requires an external switch
Plus Dish 500+ on the TechPortal
Pointing Angles (PDF)
Channels available at 118.75°
Post Number: 22
LK,
Thanks for responding but the superdish I have is for Direct and not dish.Will this setup work ?What should I look for in Antenna setup ?
Username: Lklives
Post Number: 12147
Now U say U have a Superdish...before U said U had a Dish 500 plus with a pic...they are completely different dishes...and Superdish is for DN, not DTV....cannot help U, until U know what U're talking about ...
Username: Nydas
Post Number: 3815
This is LK's help. She is a pest. Be careful.
LK
Platinum Member Username: Lklives
Post Number: 12158 Registered: Jan-06
Posted on Thursday, September 20, 2007 - 06:03 pm: in the "New Keys" thread
Do U even have a dish?...
does it have LNB's...
are they aligned correctly at whatever satellites U want....
are cables and connections rechecked
have U rechecked your switch..
did U input the latest bin
is autoroll turned ON...
did U set default key first
did U wait patiently for keys to autoroll
did U reboot....
is receiver antenna settings configured the same as your cables and switch ports and type...
have U read at least 10 hours before attempting this hobby...
do U have a manual for your receiver...
have U read it lately...
Post Number: 23
It is DTV International Dish Antenna sized 36" x 24". Do I look for 95W and 101W satellites in Antenna Setup ?
Username: Lklives
Post Number: 12161
Nalin ...U only copy/paste my posts and do NOT provide ANY useful purpose here...U are a disgrace to your own people...
Dum....U cannot get Directv, unless U subscribe....so forget DTV 95-101..
Username: Nydas
Post Number: 3824
LK only understands Braille these days.
You could have asked in plain normal easy to understand (even by LK) English that "What LNBs should I buy to use with this huge Dish I have?" and she would have said "You can install 4 cheap LNBs on an arm and get all the different channels."
Mind you I am not LK I am that dumb guy who does not know a thing.
Username: Lklives
Post Number: 12164
Atlanta Air Traffic Control: "Tower to Saudi Air 911 -- You are cleared to land eastbound on runway 9R."
Saudi Air: "Thank you Atlanta ATC Acknowledge cleared to land on infidel's runway 9R - Allah be Praised.
Atlanta ATC: "Tower to Iran Air 711 --You are cleared to land westbound on runway 9R."
Iran Air: "Thank you Atlanta ATC. We are cleared to land on infidel's runway 9R. - Allah is Great.
Pause:
Static..
Saudi Air: " ATLANTA ATC - ATLANTA ATC"
Atlanta ATC: "Go ahead Saudi Air 911?"
Saudi Air: "YOU HAVE CLEARED BOTH OUR AIRCRAFT FOR THE SAME RUNWAY GOING IN OPPOSITE DIRECTIONS. WE ARE ON A COLLISION COURSE. INSTRUCTIONS, PLEASE.
Atlanta ATC: "Well bless your hearts and praise Jesus. Y'all be careful now and tell Allah 'hey' for us."
Post Number: 24
Guys,
All I want this channel Bev ch 703 (satellite 91)..I had DTV before and now I don't, so I want use that same dish and get this channel and other Asian Channels.
Also I have DP34 Switch, can I use the same along with this dish ?
Please let us know.
Username: Tapeman
New York City in-HD, NY
Post Number: 1464
Dude
LK is right the dish is for Dishnet
The Middle LNB is for the FSS 118.75
The 2 side LNBs CAN get 91 or 82
With careful installation can get both
Not easy but possible
I would cover middle LNB with a paper cup or tape
If possible not even plug the coax in
I always thought Middle LNB has to be the FSS I never seen one but even if it is the side LNB can still get both birds. In that case yo don't need to cover LNB
Not for a noobie to test but what the heck give it a shot.
I'm here if yo got questions
Username: Tapeman
Post Number: 1465
Ooops I only saw first post
If your dish is a DTV
Yes yo can only get either 91 or 82 with the LNB that gets 101
They won't be blockage on that LNB
Yo'll need to repoint dish turn dish slightly counter clockwise and elevation also slightly up or down based on your location 101 to 92 (East cost yo move up, west yo move down)
Post Number: 25
Thanks Guys, where can I get exact elevation and other information to point the dish to get BEV channels. Also what is satellite I need to look for in the Antenna setup ?
Username: Tapeman
Post Number: 1467
http://www.kusat.com/install/calculator2.php
Username: Tapeman
Post Number: 1468
I wouldn't worry about calculation
Draw a marker line as a reference on both Elevation and Azmith Angle.
If yo make a mistake start all over from reference line
Since yo are there at 101
Very small tweeks
Turn on Beep option if yo got one on your receiver
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 3157
Dude, King is right. Here's what needs to done.
http://i4.tinypic.com/4pv97wg.jpg
