Flu to 2700 -213bin. Won't accept channel list download
Username: Realtorkim
INDIANA United States
Post Number: 19
I originally had Flu converted to 2700 with the 205 and 208 no problem.
I saved channel list, downloaded to 2700 no problem.
When using the new 213, converted pansat will not
accept channel list.(Possible Not enough memory?)
and just re-scan ?
Thank-You All I Read found no other similar posts.
AV did your bin erase your channel list? Did you download or have to rescan?
Kim
Username: Asharfi
Post Number: 824
Kimerly,
Yes, when I downloaded the new bin into my converted FLU, all of my channels were gone/deleted. I had to re-scan all of my 3 satellite dishes and now all is working.
Post Number: 20
Thanks AV, for your help in the past also.
I think I'll upgrade soon.
Kimberly
Username: La_estrella
Post Number: 13
Rescanning and select channels you whant is time consuming, so follow the steps and you are done!
Last night I recovered a Fortec Lifetime Ultra from death, with the 27.02 bin, then I converted to 2700 with the jwh_205 converter bin , then I put the jwh_213 directly, and last I modified channel master list to have only 119-110, and Saved to my converted box as a IMPORTANT --> 2700 channel list <-- It worked great!, did autoroll and stat watching TV. I followed the LK posts and others from this forum and gathered all the info.
Thanks to all those users LK, AV, Nadia
Good job!
