pls help me i know i have the crapiest receiver ariza 700, the problem i am having is when ever i update the bin file i have to rescan every channel again and i have to go thru installation setting all over again. but this time when i put the bin file 299e released on 12th sep when i was doing the instalaton settiings the quality signal bar was not showing the strenght of the signal it use to show can u hlp me solve this issue i tried the factory setting option to but it dosent work or is it time to but a new receiver which one is the best receiver pls suggest thanks
I got a VS Ultra to replace my Ariza 700 actually. When you load new bins on the Ultra, you do not lose your Channels/Sat configuration like with the Ariza. One watchout though, the picture quality may not be as good with the Viewsat. The Ariza has better picture quality than the Ultra using the S-Video output when it comes to detail and brightness. I have never tried the component outs on the Viewsat. However for reliability/support, the Viewsat can't be beat.
