Help - Setting up of Second Dish
Username: Yashmatharu
Brampton, Ont Canada
Post Number: 136
Hi Friends,
I have two receivers (Pansat 2700 FLU & CS7000 PVR) and one dish (round and may be 18") pointing at 61.5W with dual lnb. Yesterday I bought another dish to position 91W (it is not round).
Can you please confirm that the 2nd dish is right to position 91W?
Username: Banti
Post Number: 219
never heard of a dish that is not round. maybe u can mainly all dish can catch satellites try it.
Username: Rtap
FL
Post Number: 437
go to the recommended site thread by lk there you will find the list that will answer your question on dish pointing
Username: Lklives
Post Number: 12091
Banti...there are many common elliptical dishes 20 x 24, which are NOT round
Yash...the 2nd dish should be fine as long as it has circular , not linear LNB, for the 91W Bev..I myself would align it towards either the 110 or 119...Bev sucks, IMO...
yes fo the the "List of recommended sites" thread here, and use ANY one of them...they all have dish pointing tips...and sat finder calculators too...
U may want to invest in a cheap $15 sat finder meter, or use an old DN unsubscribed receiver to help U align the 2nd dish...
Post Number: 137
LK,
Thanks for your feedback. I am planning to potion to 91W only till T20 cricket world cup is over then I would put on PPV movie channels. Which one (110 or 119)has more movie channel with less adult one?
Username: Lklives
Post Number: 12093
U go here and check out the various dishnet (DN) channel lists...U pick what U want...
http://ekb.dbstalk.com/dishlist.htm
Post Number: 139
Thanks LK.
I install one more dish. Now I have two dish and two receiver therefore, have two switch. Do I need to make any changes in the settings of my receivers. I am not getting my channls after putting my cable thru switches.
Post Number: 142
Now I am getting my channels.
I have been trying to position my dish to 91W since last couple of days but no success. Infact I don't see any other satelite other than 61.5W.
What am I doing wrong. Is 91W is in different elevation?
Username: Lklives
Post Number: 12121
does it look like this?
it should...now just change the settings to correspond....
BTW...notice left side of LNB's goes to same port on each disque...same with the right side..
freq 11250
Username: Lklives
Post Number: 12122
sorry my mistake...notice how 1 sat (LNB) goes to same port # on each switch..same with the other sat (LNB)...
Username: Tapeman
New York City in-HD, NY
Post Number: 1441
Yo got it right boss
It should work
They are 2 inpendent ports of the LNBs
It will be a problem if yo mismatch the DISEqC input ports.
That can affect setup during polarity switching.
But yo got it right
Username: Rolando
Sorry, what I need is the master pin code for Pansat 2500a
Post Number: 143
still finding problem in installing both satellite in my CS7000 PVR. I can only load one of them.
Do i need to make any changes in my settings? in disec, etc
Username: Crazy_greek
Post Number: 1147
Hey, Billy
Try 1668 and 1010
