Gold Member Username: NydasPost Number: 3684 Registered: Jun-06 | Till yesterday there was key morphing on the first number of Key 00 and of Key 01. Since yesterday the key morphing has changed ot the second number. The logic applied is the same. Real_2nd_number = autorolled_2nd_number XOR 43H I will publish the table in my second post for those who want to work from a table. It is great to be able to use a table if you can't access the internet or the sites are busy. |
Gold Member Username: NydasPost Number: 3685 Registered: Jun-06 | The DN ECM has changed only slightly in concept.. If you have new BIN since yesterday install it and it will correct the problem If you do not have a new BIN, let the new keys roll in under the old BIN and then turn autoroll off and change the second number of Key 00 and 2nd number of Key 01. You can either use new key posted and do a manual change. Or if you know hex arithmetic, do a XOR o\with 43 of the 2nd numbers as stated Or use the table below on the second numbers. Basically, the attention of the ECM has shifted from the first number in each key to the second number of each key 1st Digit ''' 2nd Digit --------- 1st Digit ''' 2nd Digit 0 = 4 .'''' 0 = 3 ---------------- 8 = C '''. 8 = B 1 = 5 .'''' 1 = 2 ---------------- 9 = D '''. 9 = A 2 = 6 .'''' 2 = 1 ---------------- A= E '''. A = 9 3 = 7 .'''' 3 = 0 ---------------- B = F '''. B = 8 4 = 0 .'''' 4 = 7 ---------------- C = 8 '''. C = F 5 = 1 .'''' 5 = 6 ---------------- D = 9 '''. D = E 6 = 2 .'''' 6 = 5 ---------------- E = A '''. E = D 7 = 3 .'''' 7 = 4 ---------------- F = B '''. F = E |
New member Username: Flu_guyPost Number: 4 Registered: Aug-07 | Hi Nalin I have been using the XOR 43 method ever since you first told us about it, it's generally faster than looking for the keys on the internet and I use windows calculator, in scientific mode, to do the arithnetic. With regard to your new post above, I think what you are saying is that the second pair of Hex digits, in each key, is what is being morphed now instead of the first pair as before. Am I correct? |
Gold Member Username: NydasPost Number: 3703 Registered: Jun-06 | htiek. Your are right. Ever since 17th August I had to take back my old Pansat 2500 clone back from a close relative and her use my Sonicview. I have been using the XOR 43H ever since. It was on the first byte (number) of each key and now they have shifted the attention to the second byte ornumber. |
Gold Member Username: NydasPost Number: 3704 Registered: Jun-06 | Technical: A XOR (exclusive OR)in binary arithmetic in Software is equivalent to the inverter logic of hardware. 0 XOR 0 is 0 0 XOR 1 is 1 1 XOR 0 is 1 1 XOR 1 IS 0 Currently we are using 43H against the unknow number. 43H is 0100 0011 Wherever in the binary representation of 43H there is a 1, that is the bit that will be inverted. Any unknown binary number XORed with binary 1, gets inverted. |
New member Username: Flu_guyPost Number: 5 Registered: Aug-07 | Thanks, it's so easy and fast, I am surprised that it hasn't caught on. I am still using 286T in my FLU and it works fine. |
Gold Member Username: NydasPost Number: 3711 Registered: Jun-06 | There was this big talk about MAP 57 calls several months ago. So far what I have noticed is that after the keys come into your receiver from God (as opposed to entering them manually), a Map 57 call is made to alter some bits in the keys. The people who are revising the BINs are trying to figure out an answer to the specific change made at a particular time. There should and would be a method of looking at the general way in which the alteration is taking place (usually a XOR operation) and devise a software patch inside the flash that looks at the Map call in operation, figures out what it is doing and act accordingly. Anyway, I am going to try out the older BINs again and see in what way they behave under the current minor ECM. I am pretty certain that all the older BINs sin 281T would be valid now except for the same minor but identical defect. However, without testing I would not categorically say so. |
New member Username: La_estrellaPost Number: 1 Registered: Aug-07 | This is interesting, I was using 293T on my pansat 2500a clone, then I found a table to replace the first digit on the key. So I never upgraded the bin. But know is two digits so the third and four digit of the key are changing, but also I thing first digit is still changing for my pansat. So last time I second couple of digits where 96 and I changed by 53. Looking to this table 9 is D and 6 is 5 ?? I will try this table tonight Thanks |
New member Username: Flu_guyPost Number: 7 Registered: Aug-07 | Hello Estrella & Nalin What if the BIN in use already has some sort of anti-morphing correction built in, (like 294 and possibly 293), will not the keys it shows you, after rolling, be already altered, according to the method used when the BIN was made. Now that the rules have changed, with the second byte morphed instead of the first, at the receiver, both the first and the second byte could end up wrong because of this. I am still using 286T which does not try to fix the keys and is therefore unaffected. What do you think, does this make sense? As you suggested, Nalin, some kind of adaptive BIN that could automatically adapt to these changes would be the best. |
New member Username: La_estrellaPost Number: 2 Registered: Aug-07 | Ok I made the change to the last key 01 active With my bin 293T the key came complete but the two second digits where wrong wich I changed to FE I did not take note of the digits I replaced, So I could not compare with the XOR conversion. With the adaptive thing I don't know, but remember that Ngv 2 is a scrambling system and very complicated. But once you know the digits to replace the thing will be to enter this formula or replacement table to to be taken automatic once the key enters. Unfortunatelly maybe this will require more memory that my poor pansat 2500a has. |
Gold Member Username: NydasPost Number: 3718 Registered: Jun-06 | From another site where I posted this, I found out that with the 293 BIN the first number is altered - bits 6 and 7 are inverted or XOR with C0 to get the correct. With BIN 293 the second number is also altered but I do not have enough data to find the logical operation. If somebody is still using 293 or 293T, and I get the data re what came in and what it should have been and the positions in both the keys, I don't think it would be difficult to formulate a temporary rule. |
Silver Member Username: AmexPost Number: 621 Registered: Nov-06 | C&P Nalin Nyda Gold Member Username: Nydas Post Number: 3716 Registered: Jun-06 Posted on Wednesday, September 12, 2007 - 02:22 pm: -------------------------------------------------------------------------------- And it would be pointless to have TV if you did not have football. Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium i½ Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium i½ Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome i½ Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium i½ Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field i½ Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field i½ Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field i½ Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium . |
Silver Member Username: AmexPost Number: 622 Registered: Nov-06 | Oops! I got it posted in the wrong place! . |
Silver Member Username: AmexPost Number: 623 Registered: Nov-06 | C&P Nalin Nyda Gold Member Username: Nydas Post Number: 3716 Registered: Jun-06 Posted on Wednesday, September 12, 2007 - 02:22 pm: -------------------------------------------------------------------------------- And it would be pointless to have TV if you did not have football. Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium i½ Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium i½ Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome i½ Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium i½ Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field i½ Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field i½ Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field i½ Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium . |
Silver Member Username: AmexPost Number: 624 Registered: Nov-06 | Oops! I got it posted in the wrong place again! Damn! . |
Silver Member Username: DimwittPost Number: 112 Registered: Aug-06 | FCUKING GENIUS. |
Silver Member Username: AmexPost Number: 625 Registered: Nov-06 | . . |
New member Username: La_estrellaPost Number: 3 Registered: Aug-07 | Nalin I am using the 293T, today was 12:30 NOON east time 86: XX 1A XX ... I replaced by DF 96: XX 0F XX ... I replaced by CA Regards |
Silver Member Username: AmexPost Number: 626 Registered: Nov-06 | C&P Nalin Nyda Gold Member Username: Nydas Post Number: 3716 Registered: Jun-06 Posted on Wednesday, September 12, 2007 - 02:22 pm: -------------------------------------------------------------------------------- And it would be pointless to have TV if you did not have football. Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium i½ Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium i½ Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome i½ Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium i½ Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field i½ Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field i½ Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field i½ Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium . |
Silver Member Username: AmexPost Number: 627 Registered: Nov-06 | maybe somethin' wrong with damn keyboard...... . |
Gold Member Username: NydasPost Number: 3721 Registered: Jun-06 | Estrella : 293T BIN. 2nd number is being XORed with C5 hex. Inverting bits 0,2,6 and 7 I am told that the first number is being XORed with C0 |
New member Username: La_estrellaPost Number: 6 Registered: Aug-07 | Today 6pm eastern time I confirmed that XORed number for my 293T is C5. 86: came as 29 26 XX .... 64 XORed 26 with C5 and everybody is watching now! Thanks guys for this very instructional post! WOW! Just change 26 by E3 and you are done! Regards |
New member Username: Flu_guyPost Number: 8 Registered: Aug-07 | Estrella & Nalin FYI The keys just changed on DN about 1/2hr ago and I can confirm that for good ole 286T, only the second byte in each key is altered and that the magic number for the XOR is still unchanged at 43H |
New member Username: La_estrellaPost Number: 7 Registered: Aug-07 | Yes htiek, you confirm 2 things: 1st --> XOR system works 2nd --> for each ben there is a different comparison number: 286T -- 43H 293T -- C5H any one with another bin??? Regards |
New member Username: Flu_guyPost Number: 9 Registered: Aug-07 | Estrella Yes, I agree I think that most of the older bins should work with 43H because the Key Morphing thing did not start till fairly recently. Perhaps someone else can confirm this? |
Gold Member Username: NydasPost Number: 3722 Registered: Jun-06 | Estrella and htiek: Thanks for the input. Don't forget it is 2nd byte on key 00 and key 01 when you use 294T - XOR with 43H. Same on 286T Bin. What is the status of 1st byte with 293 BIN. Is it XORed with C0 or is left unaltered? On 294 and I presume on 286 the first byte is now unaltered, only the second byte affected. |
New member Username: Flu_guyPost Number: 10 Registered: Aug-07 | Hi Nalin On 286T it is just the second byte that is altered, at the moment. |
Bronze Member Username: Flu_guyPost Number: 11 Registered: Aug-07 | Hi Nalin Why am I seeing these funny characters between "1st digit" and "2nd digit" in your charts? see below: 1st Digit ''' 2nd Digit 0 = 4 .'''' 0 = 3 etc. Are you aware of this? |
Gold Member Username: NydasPost Number: 3723 Registered: Jun-06 | Ecoustics software does not allow more than one space, so to create a distance for a reasonably good looking table I had to put in ...... |
New member Username: La_estrellaPost Number: 8 Registered: Aug-07 | 6am eastern time Bin 293T status only second couple changes, still XORing C5 Regards |
Bronze Member Username: Flu_guyPost Number: 12 Registered: Aug-07 | Estrella I guess that would be the 1AM EDT key change and as with you, no changes, still 43H with 286T |
Bronze Member Username: Flu_guyPost Number: 13 Registered: Aug-07 | Hi Nalin For your table, did you try disabling the HTML code in the message? I bet that's it! |
Gold Member Username: NydasPost Number: 3724 Registered: Jun-06 | Tried disabling HTML, but did not work. Strange - it should have worked. For users of Pansat 2500, clones and FLU May also apply to other receivers not upgraded in last 3-4 days. Let key roll in first with autoroll on or off Turn autoroll off and change 2nd number in Key 00 and Key 01 If using BIN 294, 294T, 286, 286T XOR 2nd number (byte) with 43 Hex or use this table. 1st Digit-------------2nd digit 0 < --- > 4''.0 < --- > 3 1 < --- > 5''.1 < --- > 2 2 < --- > 6''.2 < --- > 1 3 < --- > 7''.4 < --- > 7 8 < --- > C''5 < --- > 6 9 < --- > D'....6 < --- > 5 A < -- > E'.....8 < --- >B B < -- > F'.'9 < --- >A E < -- > A''C < --- >F F < -- > B''D < -- > E If using BIN 293 and 293T XOR 2nd number (byte) with C5 Hex or use this table 1st Digit-----------2nd digit 0 < --- > C''.0 < --- > 5 1 < --- > D''.1 < --- > 4 2 < --- > E''.2 < --- > 7 3 < --- > F''.3 < --- > 6 4 < --- > 8''.8 < --- > D 5 < --- > 9''.9 < --- > C 6 < -- > A'.....A < --- > F 7 < -- > B'..'B < --- > E |
New member Username: La_estrellaPost Number: 9 Registered: Aug-07 | This is fun, no need to wait for bins or keys!!! Thanks again Nalin and Htiek good job! Regards |
New member Username: La_estrellaPost Number: 10 Registered: Aug-07 | Just a TIP I found that Windows Calculator can be put in scientific mode wich allows to calculate XOR easily!!! I'am doing it with my Sony Clie scientific calculator!. Regards |
Bronze Member Username: Packet_stormPost Number: 44 Registered: Aug-07 | Tried disabling HTML, but did not work. Strange - it should have worked. Idea for you ! Create a image and upload it to your posts. |
Bronze Member Username: Packet_stormPost Number: 45 Registered: Aug-07 | Or even better yet use the systems Non-Breaking Space command. |
Bronze Member Username: Flu_guyPost Number: 14 Registered: Aug-07 | Hi all The table is good because you can print it out and keep it by the TV and it is strange that turning of HTML did not work, non breaking space should work though. I have a HEX calculator too, an HP100LX, very old but still works perfectly. |
Gold Member Username: NydasPost Number: 3734 Registered: Jun-06 | Packet Storm : Thanks for the tip. However, I tried the in my own work I had done several years ago using Arachnophilia, and with html enabled it still does not work. I just tried the standard "Previous Top Next" html message that I have used a thousand times and it did not convert to html. I will experiment again when I have time. Thanks again |
Bronze Member Username: Flu_guyPost Number: 15 Registered: Aug-07 | Estrella Yes it's marvellous isn't it, always faster than looking for the keys on the internet, (although we must be grateful that there are people out there that put them up for us). My wife and I used to have a little race to see who could get them faster, but she'e mostly given up now. Thank you Nalin for sharing this technique with us. |
Bronze Member Username: Packet_stormPost Number: 47 Registered: Aug-07 | 1 2 3 4 4 3 2 1 It will work |
Bronze Member Username: Flu_guyPost Number: 16 Registered: Aug-07 | Nalin's table looks good in Courier see below: For users of Pansat 2500, clones and FLU May also apply to other receivers not upgraded in last 3-4 days. Let key roll in first with autoroll on or off Turn autoroll off and change 2nd number in Key 00 and Key 01 If using BIN 294, 294T, 286, 286T XOR 2nd number (byte) with 43 Hex or use this table. 1st Digit | ------- | 2nd digit 0 <---> 4 | ------- | 0 <---> 3 1 <---> 5 | ------- | 1 <---> 2 2 <---> 6 | ------- | 2 <---> 1 3 <---> 7 | ------- | 4 <---> 7 8 <---> C | ------- | 5 <---> 6 9 <---> D | ------- | 6 <---> 5 A <---> E | ------- | 8 <---> B B <---> F | ------- | 9 <---> A E <---> A | ------- | C <---> F F <---> B | ------- | D <---> E If using BIN 293 and 293T XOR 2nd number (byte) with C5 Hex or use this table 1st Digit | ------- | 2nd digit 0 <---> C | ------- | 0 <---> 5 1 <---> D | ------- | 1 <---> 4 2 <---> E | ------- | 2 <---> 7 3 <---> F | ------- | 3 <---> 6 4 <---> 8 | ------- | 8 <---> D 5 <---> 9 | ------- | 9 <---> C 6 <---> A | ------- | A <---> F 7 <---> B | ------- | B <---> E |
Silver Member Username: Flatulant_kittyPost Number: 367 Registered: Jul-06 | Nice chart. Verified for 293t. Verified 289t same as 294t |
New member Username: AnnejPost Number: 1 Registered: Sep-07 | Thank you for the key code table. It works perfect. Although, I have a small problem. It takes around 10 minutes to see the new keys once the picture is lost. Can you please advise? |
Silver Member Username: Flatulant_kittyPost Number: 368 Registered: Jul-06 | 10 min isn't bad. DEAL WITH IT. 3 min is good and 1 is better but 10 ain't bad and is normal. |
Bronze Member Username: La_estrellaPost Number: 11 Registered: Aug-07 | Could take longer looking over the internet Regards |
Bronze Member Username: Flu_guyPost Number: 18 Registered: Aug-07 | Josh: I haven't really timed it but my FLU with 286T seems to take 5-10 mins usually, (it varies). By the way, does anybody know what the percent readout really means? mine will usually finish at anywhere from 250 to 560% |
Gold Member Username: NydasPost Number: 3735 Registered: Jun-06 | On a Pansat clone it goes to 200-350%. At times I felt that by hurriedly turning the autoroll on, it comes in a bit faster. Then I go in, turn autoroll off and do the two XORed entries. I know it does not take more than 3 minutes, because I remember a few days ago, somebody was just about to start a song, I missed it as the keys rolled in and when the picture was finally up, the judges were about to start pronouncing on his performance. |
Gold Member Username: NydasPost Number: 3738 Registered: Jun-06 | XORind 2nd byte with 43H works so far with BIN 294T autorolls. |
Silver Member Username: Flatulant_kittyPost Number: 370 Registered: Jul-06 | Ditto 293T |
New member Username: DolybellPost Number: 1 Registered: Sep-07 | Hi, I'm new as a member, but I've been watching the posts here several days ago and the tables posted works in my 2500 clone with 293. I know about hex and XOR, but I want someone to explain me the XOR with C5. Please. |
New member Username: ZahirahmadPost Number: 1 Registered: Sep-07 | since last 3 days i need to put new keys after every few hours. is it with all or only with me? i have viewsat extreme 2000. and what r the new keyd? |
Bronze Member Username: Flu_guyPost Number: 19 Registered: Aug-07 | Zahir: Yes the keys are changing quite frequently right now on DN so this is normal. I am not that familiar with the viewsat situation at the moment, however, I see that they introduced a new bin on the 11th September, so its possible it may solve your problem. You can get it here: There is a thread in this forum specifcally for posting new keys and you can find it here: https://www.ecoustics.com/electronics/forum/home-video/259083.html |
Bronze Member Username: Flu_guyPost Number: 20 Registered: Aug-07 | Dolybel: XOR with C5 means that bits 7,6,2 and 0 of the byte are inverted. Instead of using the table, you can use the windows calculator, in scientific mode to do this operation. You can also switch modes back and forth between hex and binary to see how it all works out. Hope this helps. |
Gold Member Username: NydasPost Number: 3740 Registered: Jun-06 | You can use the table I have given or use the XOR formula A XOR (exclusive OR)in binary arithmetic in Software is equivalent to the inverter logic of hardware. 0 XOR 0 is 0 0 XOR 1 is 1 1 XOR 0 is 1 1 XOR 1 IS 0 On 286,289,294 BINs, the keys came in as Key 00: EB 29 21 '' 2nd byte should be 6A Key 01: 95 FE F5 '' 2nd byte should be BD Hex Binary|'.........|Hex Binary 29 =0010 1001''|FE =1111 1110 43 =0100 0011''|43 =0100 0011 XOR byte is 43H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values On 293 BIN, the keys came in as Key 00: EB AF 21 '' 2nd byte should be 6A Key 01: 95 78 F5 '' 2nd byte should be BD Hex Binary|'.......'|Hex Binary AF =1010 1111''|78 =0111 1000 C5 =1100 0101''|C5 =1100 0101 XOR byte is C5H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values |
Gold Member Username: NydasPost Number: 3743 Registered: Jun-06 | Estrella has suggested above the use of Windows Calculator. It is available from Start/Programs/accessories/calculator. Choose Scientific calculator, and then choose HEX in the scientific calculator. Doing Hex arithmetic becomes very easy. |
Silver Member Username: AmexPost Number: 652 Registered: Nov-06 | THIS VERY IMPORTANT INFO POSTED BY POCKET SPERM........... Packet Storm Bronze Member Username: Packet_storm Post Number: 33 Registered: Aug-07 Posted on Thursday, September 13, 2007 - 01:05 pm: -------------------------------------------------------------------------------- And it would be pointless to have TV if you did not have football. Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium � Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium � Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome � Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium � Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field � Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field � Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field � Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium . |
Silver Member Username: AmexPost Number: 653 Registered: Nov-06 | IF YOU DIDNT HAVE A CHANCE TO READ IT THE FIRST TIME, HERE IT IS AGAIN.......... THIS VERY IMPORTANT INFO POSTED BY POCKET SPERM........... Packet Storm Bronze Member Username: Packet_storm Post Number: 33 Registered: Aug-07 Posted on Thursday, September 13, 2007 - 01:05 pm: -------------------------------------------------------------------------------- And it would be pointless to have TV if you did not have football. Week 1 THU, SEP 6 HI PASSING HI RUSHING HI RECEIVING Indianapolis 41, New Orleans 10 Manning 288 Addai 118 Wayne 115 SUN, SEP 9 HI PASSING HI RUSHING HI RECEIVING Green Bay 16, Philadelphia 13 Favre 206 Westbrook 85 Driver 66 Houston 20, Kansas City 3 Schaub 225 Green 73 Johnson 142 Denver 15, Buffalo 14 Cutler 304 Henry 139 Walker 119 Pittsburgh 34, Cleveland 7 Anderson 184 Parker 109 Winslow 83 Carolina 27, St. Louis 13 Delhomme 201 Foster 94 Smith 118 Minnesota 24, Atlanta 3 Harrington 199 Peterson 103 Peterson 60 New England 38, NY Jets 14 Brady 297 Maroney 72 Moss 183 Washington 16, Miami 13 Campbell 222 Portis 98 Randle El 162 Tennessee 13, Jacksonville 10 Garrard 204 Brown 175 Northcutt 57 San Diego 14, Chicago 3 Rivers 190 Benson 42 Gates 107 Seattle 20, Tampa Bay 6 Hasselbeck 222 Alexander 105 Galloway 72 Detroit 36, Oakland 21 McCown 313 Bell 87 Curry 133 Dallas 45, NY Giants 35 Romo 345 Ward 89 Burress 144 MON, SEP 10 HI PASSING HI RUSHING HI RECEIVING Cincinnati 27, Baltimore 20 McNair 203 McGahee 77 Johnson 95 San Francisco 20, Arizona 17 Smith 126 James 92 Battle 60 Week 2 SUN, SEP 16 TIME (ET) TV RESOURCES LOCATION Buffalo at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Houston at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Atlanta at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium New Orleans at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Green Bay at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium San Francisco at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cincinnati at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Indianapolis at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Detroit 4:05 PM Fox Tickets | Travel Ford Field Dallas at Miami 4:05 PM Fox Tickets | Travel Dolphin Stadium Seattle at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium NY Jets at Baltimore 4:15 PM CBS Tickets | Travel M&T Bank Stadium Oakland at Denver 4:15 PM CBS Tickets | Travel Invesco Field Kansas City at Chicago 4:15 PM CBS Tickets | Travel Soldier Field San Diego at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, SEP 17 TIME (ET) TV RESOURCES LOCATION Washington at Philadelphia 8:30 PM ESPN Tickets | Travel Lincoln Financial Field Week 3 SUN, SEP 23 TIME (ET) TV RESOURCES LOCATION Detroit at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Miami at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Buffalo at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium St. Louis at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium San Francisco at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Indianapolis at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium San Diego at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Minnesota at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium Cleveland at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Jacksonville at Denver 4:05 PM CBS Tickets | Travel Invesco Field Cincinnati at Seattle 4:05 PM CBS Tickets | Travel Qwest Field NY Giants at Washington 4:15 PM Fox Tickets | Travel FedEx Field Carolina at Atlanta 4:15 PM Fox Tickets | Travel Georgia Dome Dallas at Chicago 8:15 PM NBC Tickets | Travel Soldier Field MON, SEP 24 TIME (ET) TV RESOURCES LOCATION Tennessee at New Orleans 8:30 PM ESPN Tickets | Travel Superdome Week 4 SUN, SEP 30 TIME (ET) TV RESOURCES LOCATION Green Bay at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Oakland at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Houston at Atlanta 1:00 PM CBS Tickets | Travel Georgia Dome Chicago at Detroit 1:00 PM Fox Tickets | Travel Ford Field Baltimore at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium St. Louis at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Carolina 4:05 PM Fox Tickets | Travel Bank of America Stadium Seattle at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Kansas City at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Pittsburgh at Arizona 4:15 PM CBS Tickets | Travel Cardinals Stadium Denver at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Philadelphia at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, OCT 1 TIME (ET) TV RESOURCES LOCATION New England at Cincinnati 8:30 PM ESPN Tickets | Travel Paul Brown Stadium � Bye: Tennessee, New Orleans, Washington, Jacksonville Week 5 SUN, OCT 7 TIME (ET) TV RESOURCES LOCATION Miami at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Atlanta at Tennessee 1:00 PM Fox Tickets | Travel LP Field Jacksonville at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium NY Jets at NY Giants 1:00 PM CBS Tickets | Travel Giants Stadium Carolina at New Orleans 1:00 PM Fox Tickets | Travel Superdome Arizona at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Cleveland at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Seattle at Pittsburgh 1:00 PM Fox Tickets | Travel Heinz Field Detroit at Washington 1:00 PM Fox Tickets | Travel FedEx Field Tampa Bay at Indianapolis 4:05 PM Fox Tickets | Travel RCA Dome San Diego at Denver 4:15 PM CBS Tickets | Travel Invesco Field Baltimore at San Francisco 4:15 PM CBS Tickets | Travel Monster Park Chicago at Green Bay 8:15 PM NBC Tickets | Travel Lambeau Field MON, OCT 8 TIME (ET) TV RESOURCES LOCATION Dallas at Buffalo 8:30 PM ESPN Tickets | Travel Ralph Wilson Stadium � Bye: Cincinnati, Oakland, Minnesota, Philadelphia Week 6 SUN, OCT 14 TIME (ET) TV RESOURCES LOCATION Minnesota at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Miami at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Washington at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Tennessee at Tampa Bay 1:00 PM CBS Tickets | Travel Raymond James Stadium St. Louis at Baltimore 1:00 PM Fox Tickets | Travel M&T Bank Stadium Houston at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Philadelphia at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Carolina at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Oakland at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium New England at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium New Orleans at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, OCT 15 TIME (ET) TV RESOURCES LOCATION NY Giants at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome � Bye: Buffalo, Denver, Detroit, Indianapolis, Pittsburgh, San Francisco Week 7 SUN, OCT 21 TIME (ET) TV RESOURCES LOCATION Tennessee at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Baltimore at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Minnesota at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Detroit 1:00 PM Fox Tickets | Travel Ford Field Arizona at Washington 1:00 PM Fox Tickets | Travel FedEx Field San Francisco at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Atlanta at New Orleans 1:00 PM Fox Tickets | Travel Superdome New England at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Kansas City at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Jets at Cincinnati 4:05 PM CBS Tickets | Travel Paul Brown Stadium Chicago at Philadelphia 4:15 PM Fox Tickets | Travel Lincoln Financial Field St. Louis at Seattle 4:15 PM Fox Tickets | Travel Qwest Field Pittsburgh at Denver 8:15 PM NBC Tickets | Travel Invesco Field MON, OCT 22 TIME (ET) TV RESOURCES LOCATION Indianapolis at Jacksonville 8:30 PM ESPN Tickets | Travel ALLTEL Stadium � Bye: Cleveland, Green Bay, San Diego, Carolina Week 8 SUN, OCT 28 TIME (ET) TV RESOURCES LOCATION Indianapolis at Carolina 1:00 PM CBS Tickets | Travel Bank of America Stadium Cleveland at St. Louis 1:00 PM CBS Tickets | Travel Edward Jones Dome NY Giants at Miami 1:00 PM Fox Tickets | Travel Philadelphia at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Pittsburgh at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Detroit at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Oakland at Tennessee 1:00 PM CBS Tickets | Travel LP Field Buffalo at NY Jets 4:05 PM CBS Tickets | Travel Giants Stadium Jacksonville at Tampa Bay 4:05 PM CBS Tickets | Travel Raymond James Stadium Houston at San Diego 4:05 PM CBS Tickets | Travel Qualcomm Stadium New Orleans at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Washington at New England 4:15 PM Fox Tickets | Travel Gillette Stadium MON, OCT 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Denver 8:30 PM ESPN Tickets | Travel Invesco Field � Bye: Atlanta, Dallas, Kansas City, Arizona, Seattle, Baltimore Week 9 SUN, NOV 4 TIME (ET) TV RESOURCES LOCATION Denver at Detroit 1:00 PM CBS Tickets | Travel Ford Field San Francisco at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Cincinnati at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Carolina at Tennessee 1:00 PM Fox Tickets | Travel LP Field Green Bay at Kansas City 1:00 PM Fox Tickets | Travel Arrowhead Stadium San Diego at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Jacksonville at New Orleans 1:00 PM CBS Tickets | Travel Superdome Washington at NY Jets 1:00 PM Fox Tickets | Travel Giants Stadium Arizona at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Cleveland 4:05 PM Fox Tickets | Travel Cleveland Browns Stadium New England at Indianapolis 4:15 PM CBS Tickets | Travel RCA Dome Houston at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum Dallas at Philadelphia 8:15 PM NBC Tickets | Travel Lincoln Financial Field MON, NOV 5 TIME (ET) TV RESOURCES LOCATION Baltimore at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field � Bye: Chicago, St. Louis, Miami, NY Giants Week 10 SUN, NOV 11 TIME (ET) TV RESOURCES LOCATION Cleveland at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Philadelphia at Washington 1:00 PM Fox Tickets | Travel FedEx Field Atlanta at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium St. Louis at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Denver at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Jacksonville at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Cincinnati at Baltimore 4:05 PM CBS Tickets | Travel M&T Bank Stadium Dallas at NY Giants 4:15 PM Fox Tickets | Travel Giants Stadium Detroit at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium Chicago at Oakland 4:15 PM Fox Tickets | Travel McAfee Coliseum Indianapolis at San Diego 8:15 PM NBC Tickets | Travel Qualcomm Stadium MON, NOV 12 TIME (ET) TV RESOURCES LOCATION San Francisco at Seattle 8:30 PM ESPN Tickets | Travel Qwest Field � Bye: New England, NY Jets, Tampa Bay, Houston Week 11 SUN, NOV 18 TIME (ET) TV RESOURCES LOCATION Cleveland at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium San Diego at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Miami at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Pittsburgh at NY Jets 1:00 PM CBS Tickets | Travel Giants Stadium Oakland at Minnesota 1:00 PM CBS Tickets | Travel Metrodome Kansas City at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Carolina at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field Washington at Dallas 1:00 PM Fox Tickets | Travel Texas Stadium Tampa Bay at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome New Orleans at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium New England at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Arizona at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium NY Giants at Detroit 4:15 PM Fox Tickets | Travel Ford Field St. Louis at San Francisco 4:15 PM Fox Tickets | Travel Monster Park Chicago at Seattle 8:15 PM NBC Tickets | Travel Qwest Field MON, NOV 19 TIME (ET) TV RESOURCES LOCATION Tennessee at Denver 8:30 PM ESPN Tickets | Travel Invesco Field Week 12 THU, NOV 22 TIME (ET) TV RESOURCES LOCATION Green Bay at Detroit 12:30 PM Fox Tickets | Travel Ford Field NY Jets at Dallas 4:15 PM CBS Tickets | Travel Texas Stadium Indianapolis at Atlanta 8:15 PM NFL Tickets | Travel Georgia Dome SUN, NOV 25 TIME (ET) TV RESOURCES LOCATION Seattle at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Minnesota at NY Giants 1:00 PM Fox Tickets | Travel Giants Stadium Buffalo at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium New Orleans at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Washington at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Houston at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Denver at Chicago 1:00 PM CBS Tickets | Travel Soldier Field Oakland at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium San Francisco at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at San Diego 4:15 PM CBS Tickets | Travel Qualcomm Stadium Philadelphia at New England 8:15 PM NBC Tickets | Travel Gillette Stadium MON, NOV 26 TIME (ET) TV RESOURCES LOCATION Miami at Pittsburgh 8:30 PM ESPN Tickets | Travel Heinz Field Week 13 THU, NOV 29 TIME (ET) TV RESOURCES LOCATION Green Bay at Dallas 8:15 PM NFL Tickets | Travel Texas Stadium SUN, DEC 2 TIME (ET) TV RESOURCES LOCATION San Diego at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Houston at Tennessee 1:00 PM CBS Tickets | Travel LP Field Jacksonville at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Buffalo at Washington 1:00 PM CBS Tickets | Travel FedEx Field San Francisco at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Detroit at Minnesota 1:00 PM Fox Tickets | Travel Metrodome NY Jets at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Atlanta at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Seattle at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Tampa Bay at New Orleans 1:00 PM Fox Tickets | Travel Superdome Cleveland at Arizona 4:05 PM CBS Tickets | Travel Cardinals Stadium Denver at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum NY Giants at Chicago 4:15 PM Fox Tickets | Travel Soldier Field Cincinnati at Pittsburgh 8:15 PM NBC Tickets | Travel Heinz Field MON, DEC 3 TIME (ET) TV RESOURCES LOCATION New England at Baltimore 8:30 PM ESPN Tickets | Travel M&T Bank Stadium Week 14 THU, DEC 6 TIME (ET) TV RESOURCES LOCATION Chicago at Washington 8:15 PM NFL Tickets | Travel FedEx Field SUN, DEC 9 TIME (ET) TV RESOURCES LOCATION Carolina at Jacksonville 1:00 PM Fox Tickets | Travel ALLTEL Stadium NY Giants at Philadelphia 1:00 PM Fox Tickets | Travel Lincoln Financial Field Pittsburgh at New England 1:00 PM CBS Tickets | Travel Gillette Stadium St. Louis at Cincinnati 1:00 PM Fox Tickets | Travel Paul Brown Stadium Tampa Bay at Houston 1:00 PM Fox Tickets | Travel Reliant Stadium Miami at Buffalo 1:00 PM CBS Tickets | Travel Ralph Wilson Stadium Oakland at Green Bay 1:00 PM CBS Tickets | Travel Lambeau Field Dallas at Detroit 1:00 PM Fox Tickets | Travel Ford Field San Diego at Tennessee 1:00 PM CBS Tickets | Travel LP Field Minnesota at San Francisco 4:05 PM Fox Tickets | Travel Monster Park Arizona at Seattle 4:05 PM Fox Tickets | Travel Qwest Field Cleveland at NY Jets 4:15 PM CBS Tickets | Travel Giants Stadium Kansas City at Denver 4:15 PM CBS Tickets | Travel Invesco Field Indianapolis at Baltimore 8:15 PM NBC Tickets | Travel M&T Bank Stadium MON, DEC 10 TIME (ET) TV RESOURCES LOCATION New Orleans at Atlanta 8:30 PM ESPN Tickets | Travel Georgia Dome Week 15 THU, DEC 13 TIME (ET) TV RESOURCES LOCATION Denver at Houston 8:15 PM NFL Tickets | Travel Reliant Stadium SAT, DEC 15 TIME (ET) TV RESOURCES LOCATION Cincinnati at San Francisco 8:15 PM NFL Tickets | Travel Monster Park SUN, DEC 16 TIME (ET) TV RESOURCES LOCATION Jacksonville at Pittsburgh 1:00 PM CBS Tickets | Travel Heinz Field Atlanta at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Seattle at Carolina 1:00 PM Fox Tickets | Travel Bank of America Stadium Green Bay at St. Louis 1:00 PM Fox Tickets | Travel Edward Jones Dome Baltimore at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium NY Jets at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Arizona at New Orleans 1:00 PM Fox Tickets | Travel Superdome Buffalo at Cleveland 1:00 PM CBS Tickets | Travel Cleveland Browns Stadium Tennessee at Kansas City 1:00 PM CBS Tickets | Travel Arrowhead Stadium Indianapolis at Oakland 4:05 PM CBS Tickets | Travel McAfee Coliseum Detroit at San Diego 4:15 PM Fox Tickets | Travel Qualcomm Stadium Philadelphia at Dallas 4:15 PM Fox Tickets | Travel Texas Stadium Washington at NY Giants 8:15 PM NBC Tickets | Travel Giants Stadium MON, DEC 17 TIME (ET) TV RESOURCES LOCATION Chicago at Minnesota 8:30 PM ESPN Tickets | Travel Metrodome Week 16 THU, DEC 20 TIME (ET) TV RESOURCES LOCATION Pittsburgh at St. Louis 8:15 PM NFL Tickets | Travel Edward Jones Dome SAT, DEC 22 TIME (ET) TV RESOURCES LOCATION Dallas at Carolina 8:15 PM NFL Tickets | Travel Bank of America Stadium SUN, DEC 23 TIME (ET) TV RESOURCES LOCATION Oakland at Jacksonville 1:00 PM CBS Tickets | Travel ALLTEL Stadium Washington at Minnesota 1:00 PM Fox Tickets | Travel Metrodome Miami at New England 1:00 PM CBS Tickets | Travel Gillette Stadium Philadelphia at New Orleans 1:00 PM Fox Tickets | Travel Superdome Kansas City at Detroit 1:00 PM CBS Tickets | Travel Ford Field Cleveland at Cincinnati 1:00 PM CBS Tickets | Travel Paul Brown Stadium Green Bay at Chicago 1:00 PM Fox Tickets | Travel Soldier Field NY Giants at Buffalo 1:00 PM Fox Tickets | Travel Ralph Wilson Stadium Houston at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome Atlanta at Arizona 4:05 PM Fox Tickets | Travel Cardinals Stadium Baltimore at Seattle 4:15 PM CBS Tickets | Travel Qwest Field NY Jets at Tennessee 4:15 PM CBS Tickets | Travel LP Field Tampa Bay at San Francisco 8:15 PM NBC Tickets | Travel Monster Park MON, DEC 24 TIME (ET) TV RESOURCES LOCATION Denver at San Diego 8:00 PM ESPN Tickets | Travel Qualcomm Stadium Week 17 SAT, DEC 29 TIME (ET) TV RESOURCES LOCATION New England at NY Giants 8:15 PM NFL Tickets | Travel Giants Stadium SUN, DEC 30 TIME (ET) TV RESOURCES LOCATION Buffalo at Philadelphia 1:00 PM CBS Tickets | Travel Lincoln Financial Field Cincinnati at Miami 1:00 PM CBS Tickets | Travel Dolphin Stadium Pittsburgh at Baltimore 1:00 PM CBS Tickets | Travel M&T Bank Stadium Dallas at Washington 1:00 PM Fox Tickets | Travel FedEx Field Carolina at Tampa Bay 1:00 PM Fox Tickets | Travel Raymond James Stadium Tennessee at Indianapolis 1:00 PM CBS Tickets | Travel RCA Dome New Orleans at Chicago 1:00 PM Fox Tickets | Travel Soldier Field Jacksonville at Houston 1:00 PM CBS Tickets | Travel Reliant Stadium Seattle at Atlanta 1:00 PM Fox Tickets | Travel Georgia Dome Detroit at Green Bay 1:00 PM Fox Tickets | Travel Lambeau Field San Francisco at Cleveland 1:00 PM Fox Tickets | Travel Cleveland Browns Stadium Minnesota at Denver 4:15 PM Fox Tickets | Travel Invesco Field San Diego at Oakland 4:15 PM CBS Tickets | Travel McAfee Coliseum St. Louis at Arizona 4:15 PM Fox Tickets | Travel Cardinals Stadium if not go to http://sports.espn.go.com/nfl/schedule?campaign=PSGeneral Kansas City at NY Jets 8:15 PM NBC Tickets | Travel Giants Stadium . |
Platinum Member Username: LklivesPost Number: 12024 Registered: Jan-06 | Oooops!...lmao |
Silver Member Username: Bill038Post Number: 116 Registered: Sep-06 | I missed the info the first 5 or 6 times it was posted, could you please post the nfl schedule again? |
Silver Member Username: AmexPost Number: 654 Registered: Nov-06 | MAYBE IF YOU ASK'IM, HE CAN POST IT AGAIN...... BUT RIGHT NOW HE'S KINDA BUSY.......... . |
New member Username: GiantstretchPost Number: 3 Registered: Sep-07 | I have been out of satellite service for at least 4 years ... card is gone and I have a direct tv system .... what does the discussion about "keys" refer to? THanks, |
Gold Member Username: NydasPost Number: 3747 Registered: Jun-06 | https://www.ecoustics.com/electronics/forum/home-video/350855.html Bill Vickers Silver Member Username: Bill038 Post Number: 116 Registered: Sep-06 The information you are looking for is posted in the following threads. https://www.ecoustics.com/electronics/forum/home-video/386528.html https://www.ecoustics.com/electronics/forum/home-video/387222.html https://www.ecoustics.com/electronics/forum/home-video/388036.html |
Gold Member Username: NydasPost Number: 3754 Registered: Jun-06 | You can use the table I have given or use the XOR formula A XOR (exclusive OR)in binary arithmetic in Software is equivalent to the inverter logic of hardware. 0 XOR 0 is 0 0 XOR 1 is 1 1 XOR 0 is 1 1 XOR 1 IS 0 On 286,289,294 BINs, the keys came in as Key 00: EB 29 21 '' 2nd byte should be 6A Key 01: 95 FE F5 '' 2nd byte should be BD Hex Binary|'.........|Hex Binary 29 =0010 1001''|FE =1111 1110 43 =0100 0011''|43 =0100 0011 XOR byte is 43H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values On 293 BIN, the keys came in as Key 00: EB AF 21 '' 2nd byte should be 6A Key 01: 95 78 F5 '' 2nd byte should be BD Hex Binary|'.......'|Hex Binary AF =1010 1111''|78 =0111 1000 C5 =1100 0101''|C5 =1100 0101 XOR byte is C5H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values |
Gold Member Username: NydasPost Number: 3755 Registered: Jun-06 | Estrella has suggested above the use of Windows Calculator. It is available from Start/Programs/accessories/calculator. Choose Scientific calculator, and then choose HEX in the scientific calculator. Doing Hex arithmetic becomes very easy. |
Silver Member Username: AmexPost Number: 659 Registered: Nov-06 | LATEST MLB SCHEDULE POSTED BY POCKET SPERM JUST MOMENTS AGO...!! ( C&P ) Sunday, September 16, 2007 Away Home Result Winning Pitcher Losing Pitcher MLB.TV Audio Royals Indians KC 4, CLE 3 Buckner (1-1) Laffey (3-2) Orioles Blue Jays BAL 8, TOR 6 Bell (4-3) Frasor (1-5) Phillies Mets PHI 10, NYM 6 Geary (3-2) Mota (2-2) Braves Nationals ATL 3, WSH 0 Hudson (16-8) Hill (4-4) Angels White Sox CWS 9, LAA 7 MacDougal (2-5) Moseley (4-3) Reds Brewers MIL 5, CIN 2 Villanueva (8-4) Belisle (8-9) Pirates Astros HOU 15, PIT 3 Backe (1-1) Maholm (10-15) Tigers Twins DET 6, MIN 4 Jurrjens (3-1) Baker (9-8) Cubs Cardinals CHC 4, STL 2 Marquis (12-8) Mulder (0-3) Marlins Rockies COL 13, FLA 0 Giants Padres SD 5, SF 1 Peavy (18-6) Lincecum (7-5) Devil Rays Mariners TB 9, SEA 2 Sonnanstine (5-9) Washburn (9-14) Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Rangers Athletics In progress Padilla (6-9) DiNardo (8-9) D-Backs Dodgers In progress Gonzalez (7-2) Loaiza (2-1) Yankees Red Sox 8:05 p.m. Clemens (6-6) Schilling (8-7) Monday, September 17, 2007 Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Orioles Yankees 7:05 p.m. Cabrera (9-16) Hughes (3-3) Buy Tigers Indians 7:05 p.m. Rogers (3-2) Byrd (15-6) Buy Marlins Braves 7:05 p.m. Kim (9-6) Smoltz (13-7) Buy Mets Nationals 7:05 p.m. Lawrence (1-2) Redding (3-5) Buy Red Sox Blue Jays 7:07 p.m. Wakefield (16-10) McGowan (10-9) Buy Reds Cubs 8:05 p.m. Arroyo (9-14) Hill (9-8) Buy Brewers Astros 8:05 p.m. Gallardo (8-4) Albers (4-8) Buy White Sox Royals 8:10 p.m. Vazquez (12-8) Davies (6-13) Buy Phillies Cardinals 8:10 p.m. Kendrick (8-4) TBD Buy Rangers Twins 8:10 p.m. Volquez (2-1) Slowey (3-0) Buy Giants D-Backs 9:40 p.m. Correia (4-6) Webb (16-10) Buy Pirates Padres 10:05 p.m. Van Benschoten (0-5) Cassel (0-0) Buy Mariners Athletics 10:05 p.m. Batista (13-11) Haren (14-7) Buy Devil Rays Angels 10:05 p.m. Jackson (4-14) Escobar (17-7) Buy Tuesday, September 18, 2007 Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Dodgers Rockies GM 1: 3:05 p.m. Billingsley (11-4) Francis (15-8) Buy Orioles Yankees 7:05 p.m. Leicester (2-1) TBD Buy Tigers Indians 7:05 p.m. Verlander (17-5) Westbrook (5-9) Buy Mets Nationals 7:05 p.m. Maine (14-9) Hanrahan (4-3) Buy Red Sox Blue Jays 7:07 p.m. Lester (4-0) Burnett (8-7) Buy Marlins Braves 7:35 p.m. Seddon (0-0) Reyes (0-2) Buy Reds Cubs 8:05 p.m. Harang (15-4) Zambrano (16-12) Buy Brewers Astros 8:05 p.m. Sheets (12-5) Paulino (0-0) Buy White Sox Royals 8:10 p.m. Floyd (1-3) Meche (8-12) Buy Phillies Cardinals 8:10 p.m. Hamels (14-5) TBD Buy Rangers Twins 8:10 p.m. Millwood (9-12) Silva (11-14) Buy Dodgers Rockies GM 2: 8:35 p.m. Wells (8-8) Redman (1-4) Buy Giants D-Backs 9:40 p.m. Sanchez (1-4) Owings (6-8) Buy Pirates Padres 10:05 p.m. Gorzelanny (14-7) Maddux (12-10) Buy Mariners Athletics 10:05 p.m. Weaver (6-12) Gaudin (11-11) Buy Devil Rays Angels 10:05 p.m. Hammel (2-4) Lackey (16-9) Buy . |
Silver Member Username: AmexPost Number: 660 Registered: Nov-06 | PLAY BALL.....!! LATEST MLB SCHEDULE POSTED BY POCKET SPERM JUST MOMENTS AGO...!! ( C&P ) Sunday, September 16, 2007 Away Home Result Winning Pitcher Losing Pitcher MLB.TV Audio Royals Indians KC 4, CLE 3 Buckner (1-1) Laffey (3-2) Orioles Blue Jays BAL 8, TOR 6 Bell (4-3) Frasor (1-5) Phillies Mets PHI 10, NYM 6 Geary (3-2) Mota (2-2) Braves Nationals ATL 3, WSH 0 Hudson (16-8) Hill (4-4) Angels White Sox CWS 9, LAA 7 MacDougal (2-5) Moseley (4-3) Reds Brewers MIL 5, CIN 2 Villanueva (8-4) Belisle (8-9) Pirates Astros HOU 15, PIT 3 Backe (1-1) Maholm (10-15) Tigers Twins DET 6, MIN 4 Jurrjens (3-1) Baker (9-8) Cubs Cardinals CHC 4, STL 2 Marquis (12-8) Mulder (0-3) Marlins Rockies COL 13, FLA 0 Giants Padres SD 5, SF 1 Peavy (18-6) Lincecum (7-5) Devil Rays Mariners TB 9, SEA 2 Sonnanstine (5-9) Washburn (9-14) Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Rangers Athletics In progress Padilla (6-9) DiNardo (8-9) D-Backs Dodgers In progress Gonzalez (7-2) Loaiza (2-1) Yankees Red Sox 8:05 p.m. Clemens (6-6) Schilling (8-7) Monday, September 17, 2007 Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Orioles Yankees 7:05 p.m. Cabrera (9-16) Hughes (3-3) Buy Tigers Indians 7:05 p.m. Rogers (3-2) Byrd (15-6) Buy Marlins Braves 7:05 p.m. Kim (9-6) Smoltz (13-7) Buy Mets Nationals 7:05 p.m. Lawrence (1-2) Redding (3-5) Buy Red Sox Blue Jays 7:07 p.m. Wakefield (16-10) McGowan (10-9) Buy Reds Cubs 8:05 p.m. Arroyo (9-14) Hill (9-8) Buy Brewers Astros 8:05 p.m. Gallardo (8-4) Albers (4-8) Buy White Sox Royals 8:10 p.m. Vazquez (12-8) Davies (6-13) Buy Phillies Cardinals 8:10 p.m. Kendrick (8-4) TBD Buy Rangers Twins 8:10 p.m. Volquez (2-1) Slowey (3-0) Buy Giants D-Backs 9:40 p.m. Correia (4-6) Webb (16-10) Buy Pirates Padres 10:05 p.m. Van Benschoten (0-5) Cassel (0-0) Buy Mariners Athletics 10:05 p.m. Batista (13-11) Haren (14-7) Buy Devil Rays Angels 10:05 p.m. Jackson (4-14) Escobar (17-7) Buy Tuesday, September 18, 2007 Away Home Time (ET) Away Probable Home Probable MLB.TV Tickets Dodgers Rockies GM 1: 3:05 p.m. Billingsley (11-4) Francis (15-8) Buy Orioles Yankees 7:05 p.m. Leicester (2-1) TBD Buy Tigers Indians 7:05 p.m. Verlander (17-5) Westbrook (5-9) Buy Mets Nationals 7:05 p.m. Maine (14-9) Hanrahan (4-3) Buy Red Sox Blue Jays 7:07 p.m. Lester (4-0) Burnett (8-7) Buy Marlins Braves 7:35 p.m. Seddon (0-0) Reyes (0-2) Buy Reds Cubs 8:05 p.m. Harang (15-4) Zambrano (16-12) Buy Brewers Astros 8:05 p.m. Sheets (12-5) Paulino (0-0) Buy White Sox Royals 8:10 p.m. Floyd (1-3) Meche (8-12) Buy Phillies Cardinals 8:10 p.m. Hamels (14-5) TBD Buy Rangers Twins 8:10 p.m. Millwood (9-12) Silva (11-14) Buy Dodgers Rockies GM 2: 8:35 p.m. Wells (8-8) Redman (1-4) Buy Giants D-Backs 9:40 p.m. Sanchez (1-4) Owings (6-8) Buy Pirates Padres 10:05 p.m. Gorzelanny (14-7) Maddux (12-10) Buy Mariners Athletics 10:05 p.m. Weaver (6-12) Gaudin (11-11) Buy Devil Rays Angels 10:05 p.m. Hammel (2-4) Lackey (16-9) Buy . |
Platinum Member Username: LklivesPost Number: 12038 Registered: Jan-06 | Buy a new receiver (Sonicview 4000) for $150 or a Captiveworks premium for $99, and input the latest bin/file which will autoroll the keys ....so U do NOTHING, but WATCH TV... This is barbaric ans primitive, this BS about figuring out the keys math....old school thinking there...its 2007 , not 1918..... |
Bronze Member Username: Packet_stormPost Number: 66 Registered: Aug-07 | hexadecimal in 1918 ROLLING on the floor OH boy this guy LK to much. How can one be so clueless and make it through life. Free-tvers rot and waste away sitting in front of a TV like yourself Warthog. Testers work at it. Thats the fun. |
Silver Member Username: NbnPost Number: 209 Registered: Aug-07 | who said anything about hex in 1918 ? besides the ignorant brown pieces of sh*t muslim denying paki storm |
Bronze Member Username: Packet_stormPost Number: 70 Registered: Aug-07 | old school thinking there...its 2007 , not 1918..... Learn to read first! Comprehension comes later. in making reference to the years above on is comparing what is now and what was then. Fish barrels oh what fun! |
Silver Member Username: AmexPost Number: 666 Registered: Nov-06 | WHAT A PATHETIC DOG......... SOMEBODY SHOULD TAKE HIM FOR A "WALK"..... . |
Gold Member Username: NydasPost Number: 3778 Registered: Jun-06 | You can use the table I have given or use the XOR formula A XOR (exclusive OR)in binary arithmetic in Software is equivalent to the inverter logic of hardware. 0 XOR 0 is 0 0 XOR 1 is 1 1 XOR 0 is 1 1 XOR 1 IS 0 On 286,289,294 BINs, the keys came in as Key 00: EB 29 21 '' 2nd byte should be 6A Key 01: 95 FE F5 '' 2nd byte should be BD Hex Binary|'.........|Hex Binary 29 =0010 1001''|FE =1111 1110 43 =0100 0011''|43 =0100 0011 XOR byte is 43H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values On 293 BIN, the keys came in as Key 00: EB AF 21 '' 2nd byte should be 6A Key 01: 95 78 F5 '' 2nd byte should be BD Hex Binary|'.......'|Hex Binary AF =1010 1111''|78 =0111 1000 C5 =1100 0101''|C5 =1100 0101 XOR byte is C5H ______________________________. 6A =0110 1010''|BD =1011 1101 Resulting Real values |
Gold Member Username: NydasPost Number: 3779 Registered: Jun-06 | Estrella has suggested above the use of Windows Calculator. It is available from Start/Programs/accessories/calculator. Choose Scientific calculator, and then choose HEX in the scientific calculator. Doing Hex arithmetic becomes very easy. |
