Bronze Member Username: Outdoorguy1Vancouver, BC Canada Post Number: 26 Registered: Nov-06 | Does anyone have a new bin for the 2700A? |
Silver Member Username: Ustaad_hcPost Number: 256 Registered: Oct-06 | not yet. |
Silver Member Username: RtapFL Post Number: 398 Registered: Jan-07 | check these sites from the DON CORLEON here. LK Platinum Member Username: Lklives Post Number: 11703 Registered: Jan-06 Posted on Thursday, September 06, 2007 - 09:54 am: All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released.. Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer.. If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now... Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information . So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby! Data Viewing Sequences [link removed] or get Keymaster 4.0 here free and NO registration is required... [link removed] this list is listed in a thread that already exist. |
Gold Member Username: Dude123Post Number: 1162 Registered: Jul-06 | yes the 2700A/E file is available now but it is only for genuine receivers and not for converted or clones so make sure you have an original receiver... |
Gold Member Username: Dude123Post Number: 1163 Registered: Jul-06 | its ine bin 211 and found on most of the sites that are listed above my post. |
Gold Member Username: NydasPost Number: 3713 Registered: Jun-06 | Actually there is a file by DoN dInErO since yesterday Pansat-C 2700 211v1 Tivo This Bin is for Beta Testers! New bin for Clone 2700's and Originals that have been updated to the new b-75. This bin fixes the autoroll issue. Please Set Default Keys after loading. Pass= dInErO Pansat-C 2700 211v1 Tivo.zip (532.2 KB, 0 views) |
Gold Member Username: NydasPost Number: 3715 Registered: Jun-06 | For those who have converted 2500 or FLU to 2700, there is a new 211 file by jvvh JVVH_2.11 for Fortec ltu conv. to 2700 -------------------------------------------------------------------------------- JVVH_2.11 for Fortec LTU Here is the LTU-2700 conversion bin. It is A/R fix and working good. Load the same way you loaded the last file and use the loader that works for you Attached Files File Type: zip jvvh 211 modded bin.ZIP (417.9 KB) |
New member Username: TheclawPost Number: 2 Registered: Sep-07 | What loader is best for the multistar 2500 cloned to the 2700 for the Jvvh bin files |
Gold Member Username: NydasPost Number: 3719 Registered: Jun-06 | The recommendation is use the same loader that you used for conversion. BL updater 1.4 has been used by many for conversion. |
New member Username: Chemo01165Post Number: 8 Registered: Nov-06 | Nalin, should I load first the 209 bin before the 211??? I currently have the 208 in my pansat, or is it possible to just bypass 209? |
Bronze Member Username: JoonkadanmonPhiladelphia, Pa Usa Post Number: 15 Registered: Sep-07 | hi folks, can somone please give me the basics of loading the BIN? AM NEW AT THIS thank you all in advance |
Bronze Member Username: JoonkadanmonPhiladelphia, Pa Usa Post Number: 17 Registered: Sep-07 | hello folks, can someone kindly explain briefly how to load Bin to my DN i HAVE a pansat 2700 a I believe I inputted the right new keys, but it still saying waiting for picture. I am new at this and I would really appreciate the info. |
Gold Member Username: Dude123Post Number: 1164 Registered: Jul-06 | Joonka, go to menu, parental control, enter 0000 for 2nd pin, scroll down to autoroll and turn off DIshnet network autoroll by using volume key on the remote. enter keys manually under nagravision 2 then press save and exit you should get your channels back. But for downloading bin files and how to guides, and loader etc visit fta websites that have been posted in the "Reputable Dss Sites" thread over and over again do some reading and you will know what you have to do. GOOD LUCK |
Gold Member Username: Dude123Post Number: 1165 Registered: Jul-06 | chemo01165 YOu don't have to flash it with 209, you can overite 211 on 208 and skip 209 with out any problems. |
New member Username: Chemo01165Post Number: 9 Registered: Nov-06 | Thanks a lot The One, I will do that. |
Bronze Member Username: Dragonfly2Post Number: 14 Registered: Jul-07 | bin file 213 is out for pansat 2700 |
Bronze Member Username: Espn3Post Number: 74 Registered: Aug-06 | jelly bean, please tell us were to find the file, what's improving and if it works with FLU to Pansat 2700 FTAs. thanks. |
Gold Member Username: Dude123Post Number: 1167 Registered: Jul-06 | Its a GC autoroll fix and only for pansat 2700 genuine receivers not for converted nor for clones.... |
Bronze Member Username: JoonkadanmonPhiladelphia, Pa Usa Post Number: 21 Registered: Sep-07 | Patrick please send bin download instructions to joonkadanmon@aol.com thanks |
