Air leaking out of my sub box...
Username: Milnerj
Saint Louis, Missouri United states
I have two 10" visonik subwoofers... (yeah, the cheap ones that come in an "all-in-one" package)... anyway, i've noticed a rattling noise coming from the subwoofer on the right when I listened with the trunk open. Upon further inspection, I felt air leaking out of the side of the box closest to the speakers... any idea how to fix this predicament my cheapness has thrown me into?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1661
well you can fix the raddling by taking a sub out and getting wither glue, calking, or some sort of sealent at liike home depot (i use stuff called goop it works great) as for the rattling just hope thats your box not the sub
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 681
When doing things such as caulking the leak, keep your subs out of the box for 24 hours.
Username: B3n07
Louisville, Ky USA
Post Number: 321
lol i had the same problem out of my kickers thought i blew one checked the box they blew it up lol
Username: Th3pwn3r
Post Number:...
Post Number: 4914
Sometimes going the cheap route costs you more money in the long run.Seal it up with some silicone or other sealant and let it dry for a day and you should be good.
