Username: Buddho81 Post Number: 38 Registered: May-06
Friday, September 14, 2007 - 21:45 GMT So i have a question on how i can get BEV in the states??? What kind of dish do I need with what type of lnb??? I am trying to get 82w and 91w nimiq Thanks in advance! would dish 500 or dish 1000 work if they're pointed in the right direction??? If someone can give a detail explanation on exactly what equipment and accessories I need I will really appreciate it!! Thanks in advance!
Username: Impala1977 Post Number: 158 Registered: Apr-06
Friday, September 14, 2007 - 22:09 GMT Dish 500 with a dish pro twin lnb. DP logo on lnb. Just run to your box.
Username: Cartier1 Post Number: 989 Registered: Feb-07
Friday, September 14, 2007 - 22:14 GMT bev is against the law in states. only dn is ok to steal
Username: Yashmatharu Brampton,
Ont
Post Number: 118 Registered: Feb-06
Saturday, September 15, 2007 - 02:09 GMT why is bev illigal and DN is not?
Username: Lklives Post Number: 11983 Registered: Jan-06
Saturday, September 15, 2007 - 02:11 GMT Its illegal to "steal" encrypted satellite signals from ANY company in ANY country!
Ont
Post Number: 120 Registered: Feb-06
Saturday, September 15, 2007 - 02:26 GMT LK, Is there any way these company can monitor as to who is stealing their signals?
1000 posts!!
Post Number: 10097 Registered: Jun-06
Saturday, September 15, 2007 - 02:34 GMT Yes it is. However why is it illegal to "receive" these signals when they are being transmitted right into my backyard even if I don't pay the provider? Isn't that FTA? They're just like the sunlight and moonlite. Will someone someday think of a way to charge for that?
Username: Lklives Post Number: 11984 Registered: Jan-06
Saturday, September 15, 2007 - 02:38 GMT Yash...they have no clue who is stealing signals...and no way to find out either, if using FTA receivers.....
Username: Chak Post Number: 1 Registered: Sep-07
Saturday, September 15, 2007 - 18:08 GMT tried using single dp lnb (91w) quality 0%, level 74% azmuth 145 elevation 45 skew ??? using pansat2700 doing something wrong? plz any more clarification will be appreciated?
Username: Satscanner Beaversbush,
Sportsmans P...
Great White ...
Post Number: 3087 Registered: Nov-06
Saturday, September 15, 2007 - 18:14 GMT Well, all your antanae adjustments vary on your location.Lk has posted sat calculators in his thread best repuable sites thread .Make sure you have the current bin flashed to your receiever which is the 213 bin now.set your antanae settings ,scan ,wait for the keys to roll and watch tv.
Sportsmans P...
Great White ...
Post Number: 3088 Registered: Nov-06
Saturday, September 15, 2007 - 18:18 GMT No quality means your not aimed properly or have incorrect antanae settings or your on a dead tp .Skew adjustment is only if your using more than one lnb or want more than one sat.
Username: Chak Post Number: 2 Registered: Sep-07
Saturday, September 15, 2007 - 18:19 GMT receiver is updated with new bin the problem is can't seem to pick up 91 bird. when i rotate the dish the quality doesn't seem to move. correct me if wrong the old or new bin .. still should be able to get quality or no? direct tv or standard dish lnb can be used?
Sportsmans P...
Great White ...
Post Number: 3089 Registered: Nov-06
Saturday, September 15, 2007 - 18:24 GMT yes depends on what dtv lnb .yes it should get quality on older bin. try another tp .then re-aim
Sportsmans P...
Great White ...
Post Number: 3090 Registered: Nov-06
Saturday, September 15, 2007 - 18:25 GMT what are your antanae settings and do u have a switch installed also?
Sportsmans P...
Great White ...
Post Number: 3091 Registered: Nov-06
Saturday, September 15, 2007 - 18:30 GMT and what type of dtv lnb are u using? You need to post all this info for more help.
Username: Chak Post Number: 3 Registered: Sep-07
Saturday, September 15, 2007 - 18:34 GMT No switch installed took it out and make things simpler dish pro lnb should work right? with dish 500 satellite Antenna settings azmuth 145 reported by sat cal from ones of lk's site lnb type dishpro lnb freq 11250 22khz off diseqc off legacy sw none skew 45 trying now tp 12384 positioner disable anything else needed? thanks much for the help
Sportsmans P...
Great White ...
Post Number: 3092 Registered: Nov-06
Saturday, September 15, 2007 - 18:39 GMT looks good, play with your dish aiming.
Sportsmans P...
Great White ...
Post Number: 3093 Registered: Nov-06
Saturday, September 15, 2007 - 18:41 GMT set lnb type to standand,then tweak the dish.
Username: Chak Post Number: 4 Registered: Sep-07
Saturday, September 15, 2007 - 18:42 GMT dish should aim in SOUTH direction to pick 91 bird right?
Sportsmans P...
Great White ...
Post Number: 3094 Registered: Nov-06
Saturday, September 15, 2007 - 18:44 GMT south west 91 degrees
Username: Chak Post Number: 5 Registered: Sep-07
Saturday, September 15, 2007 - 18:44 GMT dish should aim in SOUTH (sw se or whtever) direction to pick 91 bird right? Dish Pro LNb will be compatible with bev ?
Username: Chak Post Number: 6 Registered: Sep-07
Saturday, September 15, 2007 - 19:03 GMT picked up cbn channel 730 @12268. is this 91 or 82 bird?
Sportsmans P...
Great White ...
Post Number: 3095 Registered: Nov-06
Saturday, September 15, 2007 - 19:11 GMT nimiq 2 ....cricket....????? whats really up here dude?
Username: Chak Post Number: 7 Registered: Sep-07
Saturday, September 15, 2007 - 20:10 GMT got 82 but still no luck with 91 bird.. any suggestions or pointers? any channel on 82 shows any t20 cricket matches?
Username: Jatin1 Post Number: 1 Registered: Sep-07
Sunday, September 16, 2007 - 00:27 GMT Please! give me honest answer...please! I do have an 18 inch dish with a single LNB. With the same dish, I can easily get signal from dishnetwork's 148,129,110,119, but I'm looking for Indian (hindi)channels, that are coming out of directv 95 sat. Someone told me that I can't get signal from 95 with this dish. Is this true? If so, why?
Username: Lklives Post Number: 12004 Registered: Jan-06
Sunday, September 16, 2007 - 00:34 GMT U cannot get Directv (DTV) without a subscription... BTW...U can ONLY receive 1 satellite , if U have ONLY 1 single LNB...U have MUCH reading to do! and Galaxy3 95W is linear (V-H) LNB's where as DTV is a circular (L-R) LNB http://www.lyngsat.com/galaxy3c.html
Username: Jurj1 Post Number: 221 Registered: Jul-06
Sunday, September 16, 2007 - 00:41 GMT LMAO
Username: Jatin1 Post Number: 2 Registered: Sep-07
Sunday, September 16, 2007 - 02:23 GMT Lk..Thanks for your answer.But,it isn,t 95w is directv's sat, where all international channels are coming out of? And it isn,t that require circular LNB? If not. what dtv sat carry international? Can I pick those with FTA?
Username: Cartier1 Post Number: 1003 Registered: Feb-07
Sunday, September 16, 2007 - 02:27 GMT JATIN USE YOUR DISH FOR ECHO3 61.5W FULL OF INDIAN CHANNELS NEVER LISTEN TO SADSCAANNER HE IS WASTE OF TIME . ALL HIS ANSWERS ARE WRONGGGGGGGGGGG. IF U READ HERE SATSCANNER AND NALIN BIN NADIA AND BUSH JAMES ARE THE SAME PERSON . IGNORE HIM .
Username: Lklives Post Number: 12006 Registered: Jan-06
Sunday, September 16, 2007 - 02:54 GMT For the mentally challenged... AGAIN... U cannot get Directv (DTV) without a subscription...
Username: Jatin1 Post Number: 3 Registered: Sep-07
Sunday, September 16, 2007 - 03:39 GMT Thanks LK.....Can I get dishnetwork without subscription? if yes.... what's differenc?
Username: Jatin1 Post Number: 4 Registered: Sep-07
Sunday, September 16, 2007 - 03:45 GMT Cartier. Big thanks to you for answering my question. So you agree with Mr LK. How come we can get dishnetwork but not dtv??
Username: Cartier1 Post Number: 1013 Registered: Feb-07
Sunday, September 16, 2007 - 21:38 GMT jatin honestly you need to do lot of reading to understand what is going on in this dss world . no one will responde to your answers cuz you seems to be out of this orbit . direct.tv is not hackble so simple . think of iphone only apple make it and u can not use it with an other telefone company only with at&t. why????? becuz they have security system very difficult to break . understand . take care
Username: Nbn Post Number: 202 Registered: Aug-07
Sunday, September 16, 2007 - 21:44 GMT bad exmaple carty , the iphone was hacked two weeks ago.
Username: Jatin1 Post Number: 5 Registered: Sep-07
Sunday, September 16, 2007 - 22:57 GMT Thanks Cartier.....But it is very very strange that dish and bellexpress are still living in the last century. Why can,t they nail these cheaters?}
Username: Nbn Post Number: 205 Registered: Aug-07
Sunday, September 16, 2007 - 23:01 GMT who gives s f*uck , do you have a specific question or are you asking more crap about a conspiracy.
Username: Jatin1 Post Number: 7 Registered: Sep-07
Sunday, September 16, 2007 - 23:06 GMT Did I touch your nurves??? Get lost.
Username: Nbn Post Number: 207 Registered: Aug-07
Sunday, September 16, 2007 - 23:28 GMT you really touched my nerves, a "7" poster with the last 6 response bordering on retardedness, you almost thought somebody gave a shi*t about you. dumb f*ucking terrorist.
Username: Donnie1973 Post Number: 802 Registered: May-06
Monday, September 17, 2007 - 00:03 GMT come on guys, these new people here in this post are old people trying to get u to answer a bunch of stupid questions.
Username: Lklives Post Number: 12040 Registered: Jan-06
Monday, September 17, 2007 - 00:09 GMT of course they are...its a game Ecoustics admins and members have played for many years here...
Username: Nbn Post Number: 211 Registered: Aug-07
Monday, September 17, 2007 - 00:17 GMT danetn, we know that , but every piece of sh*it must be exposed. - he signed up yesterday - he is using a hindu name and wants carty and LK to scrap - he is asking specific questions on what to steal, - he is asking LK and carty to agree by his 4th post. - he is asking for cheaters to get caught by 6th post - he is telling me to get lost by post 7, too early , too much crap,
Username: Nbn Post Number: 212 Registered: Aug-07
Monday, September 17, 2007 - 00:18 GMT almost guaranteed its nalin or one of his paki friends from school
Username: Jatin1 Post Number: 8 Registered: Sep-07
Monday, September 17, 2007 - 03:37 GMT LOL............ I'm really entertaining my self. great site...
