NEED AMP HELP ASAP
Username: Instigator11
Post Number: 18
I just purchased a JBL GTO1201.1 amp off of ebay to replace my old HiFonics 1000d amp that blew. There was a about 2-3 months where I went without an amp so maybe things may have shifted a little bit in my car. But the problem is when I hooked up the JBL amp I didnt get any power and none of the lights lit up at all. But as I was driving today the amp all of a sudden just turned on. It was on for about 5-10 mins and then the protection light came on for about 10 seconds and then all the lights were off again. But for those 5-10 mins the music was POUNDING my 12" Alpine Type-R's. I checked the ground n redid it much better. What else could it be?? Any suggestions??
please help asap! I went to the shop and there trying to charge me $45 just to look at it.
Username: Kpa2727
Post Number: 668
replace fuses even if they look fine they can be toast.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4948
what's the voice coil config on those subs!?
I think you had problems with wires and then your amp worked at lower impedances
Username: Thunderb
Post Number: 54
Disconnect all speaker wires
Disconnect rca jacks
Turn you radio on
Test all the power connections at the amp with a multimeter.
Your power should be around 12-14.4 volts.
Your remote wire should also be 12-14.4 volts.
If you are getting power through the power wire and the remote wire , chances are the amp has internal problems
