Silver Member Username: YashmatharuBrampton, Ont Canada Post Number: 130 Registered: Feb-06 | My Pansat 2700 FLU is showing no signal. I did Bling scan but no change. Does anybody experiencing the same problem. I am using JWH 211 bin presently. LK Can you help me plzzz? |
Silver Member Username: Donnie1973Post Number: 799 Registered: May-06 | did u turn it off and on from the back? was it working before? |
Silver Member Username: RunnerguyPluto Post Number: 604 Registered: Sep-06 | Yash http://www.sterlingsatellite.com/azimuth.asp May help |
Silver Member Username: RunnerguyPluto Post Number: 605 Registered: Sep-06 | Sorry !! wrong thread |
Silver Member Username: RtapFL Post Number: 428 Registered: Jan-07 | check your switch if any. |
