Username: Pjduarte Post Number: 2 Registered: Jul-07
Friday, September 14, 2007 - 20:45 GMT After I installed the B-75 file. I have everything loaded and when I got to use my Pansat 2500A (now 2700) the remote won't work at all....Am i missing something here? And is it possible to go back and return it to a 2500A
Username: Machedonul Post Number: 227 Registered: Jul-06
Friday, September 14, 2007 - 21:19 GMT mine works except the bottom 6 keys A,B,C,D,E,F im thinking of buying pansat 2700 remotes off ebay
Username: Viruscauser Leesburg,
Georgia
Post Number: 243 Registered: Mar-07
Friday, September 14, 2007 - 21:28 GMT andrew percy did you see the guide at the bottom of the page where you enter the keys? The A-F keys work, it's just that the letters are located at different positions - not the ones we got used to.
Username: Machedonul Post Number: 228 Registered: Jul-06
Friday, September 14, 2007 - 21:30 GMT abby, you are 100% right, they do work they're just all over the place. I expressed myself incorrectly
Username: Jfk Post Number: 24 Registered: Dec-06
Friday, September 14, 2007 - 21:36 GMT duarte is this the first time you installed a b-75 bin into the box, tell me what bins you have installed into the box
Username: Yoeman50 Post Number: 1 Registered: Aug-07
Friday, September 14, 2007 - 23:00 GMT I`m also having trouble with my pansat 2500a after i convert it to 2700 my remote does not work how do i correct that
Username: Jfk Post Number: 25 Registered: Dec-06
Friday, September 14, 2007 - 23:18 GMT tell me more are you stuck on the screen that says english
Username: Jfk Post Number: 26 Registered: Dec-06
Friday, September 14, 2007 - 23:26 GMT did your box ever work after conversion
Username: Yoeman50 Post Number: 2 Registered: Aug-07
Friday, September 14, 2007 - 23:31 GMT stuck on screen that says english.
Username: Flatulant_kitty Post Number: 364 Registered: Jul-06
Friday, September 14, 2007 - 23:33 GMT Shoowee, what a newb.
Username: Artista2000 Post Number: 2 Registered: Sep-07
Friday, September 14, 2007 - 23:34 GMT I converted my 2500 to 2700 with bin 208 and tried to put in 211 but does not load. what could be wrong?
Username: Flatulant_kitty Post Number: 365 Registered: Jul-06
Friday, September 14, 2007 - 23:40 GMT Had that problem too as well hundreds of others. Get everything ready to go then turn on the receiver and as soon as the first B shows hit download. IT WORKS. You may have to try 10 times but it works.
Username: Flatulant_kitty Post Number: 366 Registered: Jul-06
Friday, September 14, 2007 - 23:41 GMT Anthony press ok and go to antenna setup correct the settings for your setup and scan your sats.
Username: Jfk Post Number: 27 Registered: Dec-06
Friday, September 14, 2007 - 23:55 GMT anthony what bon did you load into it
Username: Jfk Post Number: 28 Registered: Dec-06
Friday, September 14, 2007 - 23:56 GMT bin
Username: Jfk Post Number: 29 Registered: Dec-06
Friday, September 14, 2007 - 23:57 GMT om is your box say b-75 when you turn it on
Username: Machedonul Post Number: 231 Registered: Jul-06
Saturday, September 15, 2007 - 00:00 GMT as soon as u reboot and u see B75 flash across your receiver, then u press WRITE BIN if u do it a second too late, it wont work its all timing!!!
Username: Jfk Post Number: 30 Registered: Dec-06
Saturday, September 15, 2007 - 00:01 GMT not true because i did my box on the 5 and it works
Username: Machedonul Post Number: 234 Registered: Jul-06
Saturday, September 15, 2007 - 00:03 GMT well, either on the B or the 7 or the 5
Username: Yoeman50 Post Number: 3 Registered: Aug-07
Saturday, September 15, 2007 - 00:52 GMT hey guys I used the fortecstarSTB Loader and the jvv_208_1 bin file
Username: Yoeman50 Post Number: 4 Registered: Aug-07
Saturday, September 15, 2007 - 00:58 GMT john doe . Saw the b57 flashing across the front and then the 5 for 30 secs and then the on sign . remote does not work
Username: Yoeman50 Post Number: 5 Registered: Aug-07
Saturday, September 15, 2007 - 00:58 GMT b-75
Username: Yoeman50 Post Number: 6 Registered: Aug-07
Saturday, September 15, 2007 - 01:13 GMT whats the model setting for the pansat 2500a?
Username: Artista2000 Post Number: 4 Registered: Sep-07
Saturday, September 15, 2007 - 05:40 GMT Thanks guys, it worked it auto rolled.bin 213 YESSSSSSSSS
