Viewsat Ultra Shows Green Bars "- - - - "
Username: Asplover
Post Number: 54
Hi,
I am new to Ultra. I kept on getting Autoroll processing since many weeks, so i loaded the new bin file 070911 and created the new opkey using VS Key 2.5 and loaded it the same way as i did the pgm file.
After loading the hex file it never came back to 0000 and than i turned off the receiver and hooked it back to satellite and now it just shows
Green bars " - - - -".
Am i ripped off now ?? or is there a way to recover this brand new box.
Please help me now what to do.
Thanks
Username: Nydas
Post Number: 3752
asp lover : If you are really desperate, then I suggest you use your null modem cable to a computer, and try uploading the factory BIN via serial port.
Username: Asplover
Post Number: 55
Thx Nalin
Yes i uploaded the factory bin and than latest bin again.
I have rescanned the channels and everything works now, i hope Autoroll will work too, lets see when the keys will change.
Username: Cartier1
Post Number: 1021
lover the keys will change tomorrow at 4 am . so weak up and see if it's autorolling . :_)
