JTag help
Username: Sitsat
Post Number: 91
Anyone in NY/NJ can help us with a Jtag of pansat 3500SD for a few bucks???????
We thought it was fried but someone opened it and checked it. He said the power is going into the box fine so a Jtag should solve this.
Username: Rtap
FL
Post Number: 412
you need patience for this.
RTAP
Username: Rtap
MIAMI , FL MIAMI Post Number: 129
Posted on Tuesday, March 13, 2007 - 10:23 am:
may not work on some computers.you may need an older version computer or laptop.
1-- i purchased my jtag cable thru ebay
2-- remove cover of sat box only 3 screws.
3-- make sure your sat box is off and your computer is not running any programs.
4-- connect your jtag cable to computer and to reciever.
5-- now turn on sat box on rear switch
6-- open skymax 2.2 can be dowloaded basically any site make sure its a recommended site.
7-- change setting under adr flash to setting 2mb (7FE00000) and make sure select LPT port 1.
8-- under connection click start and wait till complete then under flash operation select erase and wait till complete.
9-- now under flash operation you will select write a window will pop up at the bottom change from rom file to all files. then select the pansat 3500s-flash 1(29LV160CBTC-70)-full.once you selected this file skymax will automatically start the process of writing the file to your sat box.depeding on your computer it may take a while.
10-- once it says complete turn off sat box remove jtag cable.
11-- once jtag cable is removed turn on switch and
the display screen should show b70,if so you have completed this procedure correctly.
12-- now you just have to load the boot file 80 and the current bin.
13-- enjoy.
Username: Sitsat
Post Number: 92
Thanks RTAP but if I try to help my friend, I'll end up destroying the box.If someone in New York or Jersey can fix it for him to get $40 or $50, that would be good for everyone involved ;) Isn't that a safe option? ;))))
Username: Albino_midget
Post Number: 605
Its not that difficult-read directions and give it a try
or, send here
www.pansatdirect.net/usa/repairs.php
