Editing Channels on Pansat 3500SD
Username: Bengal313
Post Number: 17
What am I doing wrong? I have the latest version of CM, and the bin file (327). I am trying to edit some channel info like name and duplicates. I download the .bin file onto my SD card and then open it with CM. I make the changes and save. After reloading all the channels are there but the channel numbers are all "0". I'm sure there are lots of you that have the Pansat 3500SD. How do you change the channel list?
Username: Thechiz2
Mars, Ur anis Mine
Post Number: 287
did you do a fresh sat scan then rename ur channles something something bin.bin
did you create template ?
heck i havent edited my list in months. i just set keys to default let it roll and bam
got almost 1000 channles couple missin to me is no big deal
lol
Username: Bengal313
Post Number: 18
I figured it out. After you edit the bin file and reload it. You must redo the local channel renumbering. That fixes everything.
