Username: B3n07 Louisville,
Ky
Post Number: 296 Registered: Jul-07
Wednesday, September 12, 2007 - 04:00 GMT ok you all i am planing on buying 2 infinity perfect 10.1 and i am wanting to give them about 1000 WRMS what size box would you recomend
Username: Skibum12189 Cleveland
Post Number: 1631 Registered: Mar-06
Wednesday, September 12, 2007 - 04:04 GMT for me, i'd give em about half a cubic foot per woofer in a sealed box, but thats just me
Post Number: 1632 Registered: Mar-06
Wednesday, September 12, 2007 - 04:05 GMT possibly a little bigger, prolly up to about .75 Rec. Sealed Box Dims: 0.30 - 1.00 cu. ft. Rec. Ported Box Dims: 1.25 - 2.50 cu. ft.
Ky
Post Number: 299 Registered: Jul-07
Wednesday, September 12, 2007 - 04:10 GMT ok well my moms has 1 in a sealed incluse at .6 with 600 going to it sounds awsome but i want 1000 watts to mine which i understand means a bigger box right
