I went and downloaded the file 209 for pansat 2700 usually the file is zipped and is in api.bin format. this time its a little different its in api.rar format can someone tell me how to conver that into the bin format because the loader is not recognizing the file either...don't know what to do..and I have never expirienced this problem before either this is the first time I have seen it like that ...please help I have read enough and didn't find anything yet....
Once U have COMPLETED sucessfully this flu-2700 conversion, THEN use "jvvh 209" and the same loader U used to perform the "conversion" ..BL v1.4 updater is a common loader for this..
There are many threads here already about this for U to read, instead of posting this subject AGAIN.....
( use the loader that worked for you last time) load the jvvh_209_pwT bin hit ok if error appears.
Have reciever OFF, hook up to ythe computer like normal then turn it ON as soon as the first b appears then hit download, wait for it to complete then receiver will reboot itself pause on 5 for 30 seconds displaying ON then Channel # then you can turn it OFF You can keep the same channels that reciever already has or rescan ,it's up to you. Set the Default keys and it should roll in about a minute or so.
janetgirl
Once again,BIG thanks to Jvvh for his awesome work!
