I originally had Flu converted to 2700 with the 205 and 208 no problem. I saved channel list, downloaded to 2700 no problem. When using the new 213, converted pansat will not accept channel list.(Possible Not enough memory?) and just re-scan ? Thank-You All I Read found no other similar posts. AV did your bin erase your channel list? Did you download or have to rescan? Kim
Yes, when I downloaded the new bin into my converted FLU, all of my channels were gone/deleted. I had to re-scan all of my 3 satellite dishes and now all is working.
Rescanning and select channels you whant is time consuming, so follow the steps and you are done!
Last night I recovered a Fortec Lifetime Ultra from death, with the 27.02 bin, then I converted to 2700 with the jwh_205 converter bin , then I put the jwh_213 directly, and last I modified channel master list to have only 119-110, and Saved to my converted box as a IMPORTANT --> 2700 channel list <-- It worked great!, did autoroll and stat watching TV. I followed the LK posts and others from this forum and gathered all the info.
